Bookmark
Subscribe
1002
One sniffer interface, 2 switches (SPAN)
JanosKocka
Is it possible to send the whole traffic from 2 interconnected switches into one of its physical interface ?
I mean a monitor session, where a single destination port receives all traffic from both  switches.
6 Replies 6
balaji.bandi
in theory, You can RSPAN to another switch and SPAN to the sniffer. - it depends on models.
https://community.cisco.com/t5/networking-documents/understanding-span-rspan-and-erspan/ta-p/3144951
BB
Ok.
On the frist switch  i set all physical  interfaces as source, and a remote vlan for destination.
On the 2nd switch i set the the remote vlan as a first source, and the the sniffer connected interface as a destination. I need a second source on this switch, which contains all the local traffic. How can i set this ?
yes, correct, one the first switch you configure source and using span vlan to ship to sniffer connected switch.
on the main switch, you span to sniffer connect port.
the guide i have posted clear instruction if you have issues post the issue and configuration, so we can look and advise.
example config ;
RSPAN :
BB1(config)#vlan 100  --> make sure this vlan not used any where
BB1(config-vlan)#name RSPAN-Vlan
BB1(config-vlan)#remote-span
BB1(config-vlan)#exit
BB1(config)#monitor session 1 source interface Gi1/1 rx
BB1(config)#monitor session 1 destination remote vlan 100
BB1(config)#end
Allow VLAN 100 in the Trunn port of other switch
BB2#conf t
BB2(config)#vlan 100
BB2(config-vlan)#name RSPAN-Vlan
BB2(config-vlan)#remote-span
BB2(config-vlan)#exit
BB2(config)#monitor session 1 destination interface Gi1/2 --> where sniffer connected
BB2(config)#monitor session 1 source remote vlan 100
BB2(config)#end
BB
Sorry, but it is still only  one source, the remote switch, and it doesnt inculde the traffic on the local switch. I want to  sniff both switches at the same time on one physical interface.
I need only 1 information :
What is the second source ?
You cant mix vlans and interfaces as a source.
You cant set a monitor port as a source.
How do you send the the aggregated traffic from the 2 switches  into one monitor port?
As per my understanding, the switch does not support a combination of local SPAN and RSPAN in a single session.
I have just provided the example :
on the second switch ( BB2 - example here)  you can add as many as the source you want.
I am only looking at the end goal as long as the traffic coming to Sniffer or Wireshark is important.
BB
So there is no way to sniff 2 switches at the same time on a single interface ?
You have to connect the sniffer to two separate port, or you have to sniff the switches one by one ?
