ACE10 HTTP Error page not found
m_tarawneh
Frequent Visitor
Frequent Visitor
Dears,
I want to load balance between two webservers using ACE10 working in bridging mode, but when putting the VIP in the url i'm getting page not found, tried many configurations but didn't work, here is the latest one
logging enable
logging buffered 7
access-list ALL line 8 extended permit ip any any
rserver host test1
  ip address 172.24.1.32
  inservice
rserver host test2
  ip address 172.24.1.33
  inservice
serverfarm host ourtest
  predictor leastconns
  rserver test1
    inservice
  rserver test2
    inservice
sticky http-header Host GROUP4
  header offset 999 length 1000
  timeout 720
  timeout activeconns
  replicate sticky
  serverfarm ourtest
class-map type http loadbalance match-any L7CLASS
  10 match http header Host header-value ".*"
class-map match-any VS_WEB2
  10 match virtual-address 172.24.1.82 tcp eq www
policy-map type management first-match remote-access
  class class-default
    permit
policy-map type loadbalance first-match L7POLICY
  class L7CLASS
    sticky-serverfarm GROUP4
    insert-http Host header-value "*"
policy-map multi-match HTTP_MULTI_MATCH
  class VS_WEB2
    loadbalance policy L7POLICY
interface vlan 650
  bridge-group 1
  access-group input ALL
  no shutdown
interface vlan 801
  bridge-group 1
  service-policy input HTTP_MULTI_MATCH
  no shutdown
interface bvi 1
  ip address 172.24.1.83 255.255.255.0
  no shutdown
ip route 0.0.0.0 0.0.0.0 172.24.1.1
m_tarawneh
Frequent Visitor
Frequent Visitor
I tried to configure it as in the below link, but it didn't work
http://docwiki.cisco.com/wiki/URL_Load_Balancing_Using_Bridged_Mode_on_the_Cisco_Application_Control_Engine_Configuration_Example
hope somebody could help.
You should move this question to Application Networking Forum.
However based on link given seems to be missing -
service-policy input remote-access on server facing vlan.
Ajay
Marcel Meier
Community Member
In your
class VS_WEB2
LOADBALANCE VIP INSERVICE
Is missing
m_tarawneh
Frequent Visitor
Frequent Visitor
below the updated configuration, it didn't work until i added the redirct configuration, but i doubt that this is correct, since this will not work for other pages..
Generating  configuration....
logging enable
logging buffered  3
probe http test
passdetect  interval 5
expect status  100 500
rserver host  test1
inservice
rserver redirect  test1r
webhost-redirection  http://172.24.1.33/sites/residential/English/Pages/
inservice
rserver host  test2
inservice
rserver redirect  test2r
webhost-redirection  http://172.24.1.32/sites/residential/English/Pages/
inservice
probe  test
rserver  test1
inservice
rserver  test2
inservice
serverfarm redirect  test
rserver  test1r
inservice
rserver  test2r
inservice
class-map type http loadbalance  match-all HTTP
2 match http  url /sites/residential/English/Pages.*
10 match  virtual-address 172.24.1.82 255.255.255.0 tcp eq www
class  class-default
permit
policy-map type loadbalance  first-match HTTP_LB
class  HTTP
serverfarm  test
class  class-default
serverfarm  ourtest
class  VS_WEB2
loadbalance  vip inservice
loadbalance  policy HTTP_LB
loadbalance  vip icmp-reply
interface vlan  650
bridge-group  1
no  normalization
no  shutdown
interface vlan  801
bridge-group  1
no  normalization
no  shutdown
interface bvi 1
no  shutdown
