ACL applied on interface
grapevine
Level 5
Level 5
Can you please advise me if we could apply to acls for an interface - one inbound and the other outbound and will those be active at the same time?
Mark Malone
yes you can apply an acl in and out at the same time on an interface IP interface and there active for each way
you can also apply a layer 2 mac acl opn layer 2 ports if your software allows it
here is an example from my network i have removed the ips
interface GigabitEthernet0/0.18
 description xxxxx WLAN Ethernet
 encapsulation dot1Q 18
 ip address x.x.x.xx 255.255.255.0
 ip access-group 115 in
 ip access-group 115 out
 ip helper-address x.x.x.x
 ip accounting output-packets
 ip flow ingress
 ids-service-module monitoring
 standby 6 ip x.x.x.x
 standby 6 priority 110
 standby 6 preempt
 standby 6 track 1 decrement 2
 standby 6 track 2 decrement 2
 standby 6 track 3 decrement 2
 service-policy input DSCPTRAFFIC
access-list 115 permit udp any x.x.x.x 0.0.0.15 eq tftp
access-list 115 permit udp any host x.x.x.x eq tftp
access-list 115 deny   udp any any eq tftp log
access-list 115 permit ip any any
