ACL direction
vishalpatil86
Level 7
Level 7
hi,
i have applied following ACL to interface vlan 10 inward direction.
access-list 121 deny ip 10.86.60.0 0.0.0.127 any log
interface vlan 10
ip access-group 121 in
i tried to open google.com from 10.86.60.5, but it is denied.
here i have denied traffic from internet to my lan, then how come it is denying traffic from lan to internet?
17 Replies 17
cadet alain
ip communication is a bidirectional process.
Regards.
Alain
Hi Vishal,
The rule what you defined is wrong.
And coming to your issue, when you applied "ip access-group 121 in" It means when the packet entering to inside from the interface it will be denied as per the above defined rule.
So When you try to open google the packet is going out but the reverse packet (reverse route/traffic) is wont come as per the above rule.
So instead of that rule you need to like....
access-list 121 permit ip 10.86.60.0 0.0.0.127 any log
Please rate the helpfull posts.
Naidu.
reverse packet will come since the source will be google and destination will be 10.86.60.5 for packet cuming into vlan 10. out traffic is permitted
Vishal
Is vlan 10 using the subnet 10.86.0.0/25 ?
If so traffic will never get out of that vlan with your acl because you have denied it with your acl.
Jon
then why do we use direction in or out?
Jon Marshall
Vishal
an acl applied inbound on a vlan interface filters traffic from clients in that vlan
an acl applied outbound on a vlan interfac filters traffic to clients on that vlan
so you acl is blocking the traffic from 10.86.60.0/25 clients to the internet.
But even if you applied an outbound acl ie.
access-list 101 deny ip any 10.86.0.0 0.0.0.127
int vlan 10
ip access-group 101 out
this still wouldn't work because then the return traffic from google would be blocked.
Basically to do what you want to need a firewall (or reflexive acls). Do you not have a firewall ?
Jon
Hi Vishal,
The in/out directions will filter the packets within the vlan from its clients.
As i said you need to permit instead of deny to get internet from the clients.
Naidu.
no access-list 111
access-list 111 permit icmp 10.86.60.16 0.0.0.15 10.86.60.0 0.0.0.15
access-list 111 permit icmp 10.86.60.64 0.0.0.31 10.86.60.0 0.0.0.15
access-list 111 permit icmp 10.86.60.128 0.0.0.31 10.86.60.0 0.0.0.15
access-list 111 permit tcp 10.86.60.64 0.0.0.31 eq 53 10.86.60.0 0.0.0.15
access-list 111 permit udp 10.86.60.64 0.0.0.31 eq 53 10.86.60.0 0.0.0.15
access-list 111 permit udp 10.86.60.16 0.0.0.15 eq 161 10.86.60.0 0.0.0.15
access-list 111 permit udp 10.86.60.64 0.0.0.31 eq 161 10.86.60.0 0.0.0.15
access-list 111 permit udp 10.86.60.128 0.0.0.31 eq 161 10.86.60.0 0.0.0.15
access-list 111 permit udp 10.86.60.16 0.0.0.15 10.86.60.0 0.0.0.15 eq 161
access-list 111 permit udp 10.86.60.64 0.0.0.31 10.86.60.0 0.0.0.15 eq 161
access-list 111 permit udp 10.86.60.128 0.0.0.31 10.86.60.0 0.0.0.15 eq 161
access-list 111 permit tcp 10.86.60.64 0.0.0.31 eq 389 10.86.60.0 0.0.0.15
access-list 111 permit udp 10.86.60.64 0.0.0.31 eq 389 10.86.60.0 0.0.0.15
access-list 111 permit tcp 10.86.60.16 0.0.0.15 10.86.60.0 0.0.0.15 eq 445
access-list 111 permit tcp 10.86.60.64 0.0.0.31 10.86.60.0 0.0.0.15 eq 445
access-list 111 permit tcp 10.86.60.128 0.0.0.31 10.86.60.0 0.0.0.15 eq 445
access-list 111 permit tcp 10.86.60.16 0.0.0.15 eq 445 10.86.60.0 0.0.0.15
access-list 111 permit tcp 10.86.60.64 0.0.0.31 eq 445 10.86.60.0 0.0.0.15
access-list 111 permit tcp 10.86.60.128 0.0.0.31 eq 445 10.86.60.0 0.0.0.15
access-list 111 permit tcp 10.86.60.16 0.0.0.15 eq 443 10.86.60.0 0.0.0.15
access-list 111 permit tcp 10.86.60.64 0.0.0.31 eq 443 10.86.60.0 0.0.0.15
access-list 111 permit tcp 10.86.60.128 0.0.0.31 eq 443 10.86.60.0 0.0.0.15
access-list 111 permit udp 10.86.60.16 0.0.0.15 eq 500 10.86.60.0 0.0.0.15
access-list 111 permit udp 10.86.60.64 0.0.0.31 eq 500 10.86.60.0 0.0.0.15
access-list 111 permit udp 10.86.60.128 0.0.0.31 eq 500 10.86.60.0 0.0.0.15
access-list 111 permit tcp 10.86.60.16 0.0.0.15 eq 1026 10.86.60.0 0.0.0.15
access-list 111 permit tcp 10.86.60.64 0.0.0.31 eq 1026 10.86.60.0 0.0.0.15
access-list 111 permit tcp 10.86.60.128 0.0.0.31 eq 1026 10.86.60.0 0.0.0.15
access-list 111 permit tcp 10.86.60.64 0.0.0.31 10.86.60.0 0.0.0.15 eq 1521
access-list 111 permit tcp 10.86.60.16 0.0.0.15 eq 3268 10.86.60.0 0.0.0.15
access-list 111 permit udp 10.86.60.191 0.0.0.63 10.86.60.0 0.0.0.15 eq 7301
access-list 111 permit udp 10.86.61.0 0.0.0.127 10.86.60.0 0.0.0.15 eq 7301
access-list 111 permit tcp 10.86.60.191 0.0.0.63 eq 9100 10.86.60.0 0.0.0.15
access-list 111 permit tcp 10.86.61.0 0.0.0.127 eq 9100 10.86.60.0 0.0.0.15
access-list 111 permit udp 10.86.60.191 0.0.0.63 eq 10004 10.86.60.0 0.0.0.15
access-list 111 permit udp 10.86.61.0 0.0.0.127 eq 10004 10.86.60.0 0.0.0.15
access-list 111 permit tcp 10.86.60.191 0.0.0.63 10.86.60.0 0.0.0.15 range 1024 65535
access-list 111 permit tcp 10.86.61.0 0.0.0.127 10.86.60.0 0.0.0.15 range 1024 65535
access-list 111 permit tcp 10.86.63.0 0.0.0.255 10.86.60.0 0.0.0.15 range 1024 65535
access-list 111 permit icmp 140.95.0.0 0.0.255.255 10.86.60.0 0.0.0.15
access-list 111 permit tcp 140.95.0.0 0.0.255.255 eq 80 10.86.60.0 0.0.0.15
access-list 111 permit tcp 140.95.0.0 0.0.255.255 eq 443 10.86.60.0 0.0.0.15
access-list 111 permit tcp 140.95.0.0 0.0.255.255 10.86.60.0 0.0.0.15 eq 80
access-list 111 permit tcp 140.95.0.0 0.0.255.255 10.86.60.0 0.0.0.15 eq 443
access-list 111 permit tcp 140.95.0.0 0.0.255.255 10.86.60.0 0.0.0.15 eq 1521
access-list 111 permit tcp 140.95.0.0 0.0.255.255 10.86.60.0 0.0.0.15 eq 9001
access-list 111 permit tcp 208.89.43.0 0.0.0.255 eq 3995 10.86.60.0 0.0.0.15
access-list 111 permit tcp 172.16.0.0 0.0.0.255 eq 2463 10.86.60.0 0.0.0.15
access-list 111 permit tcp host 192.168.89.33 10.86.60.0 0.0.0.15 eq 80
access-list 111 permit tcp host 192.168.89.33 10.86.60.0 0.0.0.15 eq 3389
access-list 111 deny ip any 10.86.60.0 0.0.0.15 log
no access-list 121
access-list 121 permit ip 10.86.60.0 0.0.0.15 10.86.60.16 0.0.0.15
access-list 121 permit ip 10.86.60.0 0.0.0.15 10.86.60.64 0.0.0.31
access-list 121 permit ip 10.86.60.0 0.0.0.15 10.86.60.128 0.0.0.31
access-list 121 permit ip 10.86.60.0 0.0.0.15 10.86.60.191 0.0.0.63
access-list 121 permit ip 10.86.60.0 0.0.0.15 10.86.61.0 0.0.0.127
access-list 121 permit ip 10.86.60.0 0.0.0.15 10.86.63.0 0.0.0.255
access-list 121 permit tcp 10.86.60.0 0.0.0.15 140.95.0.0 0.0.255.255 eq 80
access-list 121 permit tcp 10.86.60.0 0.0.0.15 140.95.0.0 0.0.255.255 eq 443
access-list 121 permit tcp 10.86.60.0 0.0.0.15 eq 80 140.95.0.0 0.0.255.255
access-list 121 permit tcp 10.86.60.0 0.0.0.15 eq 1521 140.95.0.0 0.0.255.255
access-list 121 permit tcp 10.86.60.0 0.0.0.15 172.16.0.0 0.0.0.255 eq 2463
access-list 121 permit icmp 10.86.60.0 0.0.0.15 any
access-list 121 deny ip 10.86.60.0 0.0.0.15 any log
interface vlan 10
ip access-group 111 out
thats the access list i have configured.
I didn't understand above explanation
Vishal
What is the subnet used with vlan 10 ie. what is the IP address + subnet mask assigned to vlan 10 interface ?
As i said before -
inbound acl - this will filter traffic coming from clients in that vlan. So if you apply acl 121 inbound on vlan 10 then it will filter traffic from clients in vlan 10
outbound acl - if you apply acl 111 outbound on vlan 10 then it will filter traffic going to clients in vlan 10.
Jon
Hi Vishal,
ip access-group 111 in..
Applied when packet coming to the clients in that vlan
Applied when packet going out from the clients in that vlan
Coming to your access-list rules there are lot of unnecessary rules defined.
Tell us clearly what is the subnet you gave for vlan 10 and what is needs to be permit and what not.
Naidu.
vlan 10 ip 10.86.60.3 255.255.255.240
Hi Vishal,
According to your ip and subnet mask of vlan 10 try to configure like below to get internet access.
ip access-list extended 121
ip permit 10.86.60.0 0.0.0.15 any
interface vlan 10
Naidu.
Well, your acls will deny internet traffic anyway because nowhere do you allow an "any" except to deny it at the end.
Please read what has been posted about direction of traffic. If you have both an in and an out acl and you want to allow internet or http traffic you would need before the last line of your acls -
access-list 111 permit tcp any 10.86.0.0 0.0.0.15 eq http
access-list 121 permit tcp 10.86.0.0 0.0.0.15 any eq http
Jon
gazillion_dwolfe
Community Member
something great I found on a cisco forum somewhere that has always helped me to determine what direction is correct.
The "in" ACL has a source on a segment of the interface to which it is applied and a destination off of any other interface. The "out" ACL has a source on a segment of any interface other than the interface to which it is applied and a destination off of the interface to which it is applied.
maybe that will help someone else
netengdj
