How to check High backplane utilization in 6500 switch
mahesh18
Level 6
Level 6
Hi all,
Is it tru that sh system command will sh us high backplane utilization in cisco 6500 switch???
6509-A> (enable) sh system
PS1-Status PS2-Status
ok ok
Fan-Status Temp-Alarm Sys-Status Uptime d,h:m:s Logout
ok off ok 891,14:49:54 12 min
PS1-Type PS2-Type
WS-CAC-1300W WS-CAC-1300W
Modem Baud Traffic Peak Peak-Time
disable 9600 1% 22% Sat Oct 18 2008, 05:03:51
PS1 Capacity: 1153.32 Watts (27.46 Amps @42V)
PS2 Capacity: 1153.32 Watts (27.46 Amps @42V)
PS Configuration : PS1 and PS2 in Redundant Configuration.
System Name System Location System Contact CC
-6509-A
Core Dump Core File
disabled slot0:crashinfo
Crash Info Crash Info File
enabled bootflash:crashinfo
System Information Logging Host Interval
Disabled - 1440
System Information Log File
tftp:sysinfo
Index System Information Logging Commands
Syslog Dump Syslog File
disabled
in this command which option shows backplane utilization????
many thanks
mahesh
8 Replies 8
glen.grant
Yes that will show it . Also if its a 720 or 6500 with switch fabric module and fabric enable cards you can use show fabric utilization to see what is going on .
Hi glen
thanks for reply
so this part of command shows backplane utilization
disable 9600 1%>>>> 22% >>>>>>>>Sat Oct 18 2008, 05:03:51
hi jon,
thanks one again
issue solved
many thanks
mahesh
I am running IOS 12.2(33)SXH2a on my 6509 switches and need to be able to see the backplane utilization. However, with IOS 12.2(33)SXH2a, I am not able to execute the "show system" or "show catalyst6000 traffic-meter" commands to backplane utilization.
CORE_1#sh catalyst6000 traffic-meter
This Supervisor hardware revision has no support for traffic meter feature.
CORE_1#sh system
% Invalid input detected at '^' marker.
What command can I use to display the backplane utilization for a 6509 running on IOS 12.2(33)SXH2a?
thx,
David
Edison,
That document solved my issue.
Thanks!
David
thanks to guide us how this issue solved .. what is the equivalent command on IOS to get utlization peaks ?
regards
