ACL extended not working
mangsto32
We are experiencing an issue where cisco router is pinging some servers with his wan ip.
we didn't find the reason so we tried to block the ping,
Despite applying ACL, I still see logs of the ping in the firewall, it's really weird because when I try to ping the servers with the wan IP I can't:
ROUTER#ping 172.24.133.124
Sending 5, 100-byte ICMP Echos to 172.24.133.124, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 1/1/1 ms
ROUTER#ping 172.24.133.124 so
ROUTER#ping 172.24.133.124 source 198.18.100.9
Packet sent with a source address of 198.18.100.9
Success rate is 0 percent (0/5)
cisco config:
ip access-list extended Block-Ping
10 deny icmp host 198.18.100.9 any echo
20 deny icmp host 198.18.100.9 any echo-replySwitching
30 permit ip any any
interface GigabitEthernet0/0/1.60
description p2p_to_customer
encapsulation dot1Q 60
ip address 172.24.60.249 255.255.255.0
ip access-group Block-Ping out
19 Replies 19
NO need log I test ACL with log there is no hit so we need to use CoPP and I will run lab and share code here
thanks
MHM
access-list 152 permit ip host <router interface IP> <server IP>
access-list 152 deny   ip any any <<<- this mandatory
class-map match-all class-icmp
 match access-group 152
policy-map policy-icmp
 class class-icmp
   drop
control-plane
 service-policy input policy-icmp
MHM
I still didn't execute the command.
do you know if cdp may be the reason for the ping?
Cdp is use between two direct point and it l2 so sure it not relate to ping send for router to server.
And if you not run copp in router why you not only drop these ping in FW.
I prefer use acl in FW instead of using copp.
MHM
Thanks for the reply.
but I don't have access to the FW,
