CS-2960x-48FPS-L switch boot loop
Irimaso
Community Member
anyone to help with my switch, logging the following logs and rebooting automatically.
before it reboots the syst and rps lights light amber and then the fan off the reboots!
#model: CS-2960x-48FPS-L
8 Replies 8
@Irimaso
 Unfortunatelly this logs does not help much. If you have something connected to this switch I would recommend you to disconnect. If you have nothing connected to this switch and this reboot is happening spontaneously , try to upgrade or downgrade to a different IOS version.
i did upgrade and downgrade both the latest and the old ios versions but nothing worked, it still rebooted spontaneously!
sing driver version 4 for media type 1
Xmodem file system is available.
Base ethernet MAC Address: e0:89:9d:ba:d3:00
The password-recovery mechanism is enabled.
APM USBUSB EHCI 1.00
USB EHCI 1.00
USB Console INIT
Initializing Flash...
mifs[5]: 13 files, 1 directories
mifs[5]: Total bytes : 1806336
mifs[5]: Bytes used : 867840
mifs[5]: Bytes available : 938496
mifs[5]: mifs fsck took 0 seconds.
mifs[6]: 0 files, 1 directories
mifs[6]: Total bytes : 3870720
mifs[6]: Bytes used : 1024
mifs[6]: Bytes available : 3869696
mifs[6]: mifs fsck took 1 seconds.
mifs[7]: 5 files, 1 directories
mifs[7]: Total bytes : 258048
mifs[7]: Bytes used : 8192
mifs[7]: Bytes available : 249856
mifs[7]: mifs fsck took 0 seconds.
mifs[8]: 5 files, 1 directories
mifs[8]: Total bytes : 258048
mifs[8]: Bytes used : 8192
mifs[8]: Bytes available : 249856
mifs[8]: mifs fsck took 0 seconds.
mifs[9]: 265 files, 2 directories
mifs[9]: Total bytes : 122185728
mifs[9]: Bytes used : 82912768
mifs[9]: Bytes available : 39272960
mifs[9]: mifs fsck took 58 seconds.
...done Initializing Flash.
Loading "flash:/c2960x-universalk9-mz.150-2a.EX5_2.bin"...Verifying image flash:/c2960x-universalk9-mz.150-2a.EX5_2.bin.......................................................................................................................................................................................................................................................................................Image passed digital signature verification
File "fla
without IOS version consideration thats all IOS versions are showing out the reboot!
balaji.bandi
what Code running, is this stack ?
in Switch 0. Cannot read pid from Flexstack module
i would suggest to Power Down the whole stack and remove any stack cables, and boot only 1 device and check ?
have you done any recent upgrades ?
check this thread :
https://community.cisco.com/t5/switching/2960x-syst-led-amber-stable/td-p/4278326
BB
not in stack!
Leo Laohoo
Did someone upgraded the IOS of the switch just before the crashing started?
I think so but i dont know which version was there before upgrade!
If the switch "originally" came with IOS version "EX", then raise an RMA.
The most common reason why a 2960X could not upgrade outside of an "EX" release is when the switch is counterfeit.
Irimaso
Community Member
i think my switch has no stacking module instead! thanks for your help!
