ACL help on simple 2 router OSPF Lab
whiteford
I'm trying to practise with some ACL's in my small 2 router lab. On Router0 I want to be able to deny and log access from 192.168.100.192/27 (Router1 LAN) to 192.168.100.97/27 (Loopback0 LAN).
As you can see on Router0 I have created an Extended ACL and bound this to the destination interface which is the loopback0 in the "outbound" direction to the LAN. This how I have been taught to do it anyway, set the ACL on the destination interface and to outbound to the LAN of the interface.
Router0#sh run
interface Loopback0
ip address 192.168.100.97 255.255.255.224
ip access-group inbound out
interface FastEthernet0/0
ip address 192.168.100.129 255.255.255.252
duplex auto
speed auto
interface Serial0/0
description WAN link to RouterA
ip address 10.10.10.13 255.255.255.252
no fair-queue
interface Serial0/1
no ip address
router ospf 1
log-adjacency-changes
network 10.10.10.12 0.0.0.3 area 0
network 192.168.100.96 0.0.0.31 area 0
network 192.168.100.128 0.0.0.3 area 0
ip http server
no ip http secure-server
ip classless
ip access-list extended inbound
deny ip 192.168.100.192 0.0.0.31 any log
permit ip any any log
Router1#sh run
ip dhcp pool client
network 192.168.100.192 255.255.255.224
default-router 10.10.10.14
ip address 192.168.100.193 255.255.255.224
ip nat inside
duplex auto
speed auto
interface Serial0/0
ip address 10.10.10.14 255.255.255.252
ip nat outside
no fair-queue
clock rate 4000000
interface Serial0/1
no ip address
shutdown
router ospf 1
network 192.168.100.192 0.0.0.31 area 0
25 Replies 25
I think it's the way I look at it:
I see it as, I'm 192.168.21.x (the source) so:
Source-Address : 192.168.21.x (server)
Destination-Address : 10.20.20.2 (PC)
And permit ip 10.20.20.0 0.0.0.255 192.168.21.0 0.0.0.255 log doesn't fit.
:S
Andy,
What do you mean that log doesn't fit?
10.20.20.0 0.0.0.255 should be hosts,10.20.20.1-10.20.20.254.
I'm now a bit headache. (Grin)
Toshi
Sorry (my London lingo)
And permit ip 10.20.20.0 0.0.0.255 192.168.21.0 0.0.0.255 log.
I mean I would expect this to say:
permit ip 192.168.21.0 0.0.0.255 10.20.20.0 0.0.0.255 log
I see as I'm the source (192.168.21.x) so permit 192.168.21.x to 10.20.20.x
Andy,
You applied the ACL as outbound direction.
ip access-group MYACL1 out
It means, the traffic going out of the router via FastEthernet0/0. Then hit the ACL. So It's not possible to see the source as 192.168.21.X. The source would be your lan,10.20.20.x.
HTH,
Toshi
That is the part I understand, I wanted to allow 10.20.20.x outbound access only to those 3 subnets and that works, but what gives the 3 remote subnets access backwards to the 10.20.20.x?
Is it because I don't have an access inbound to the 10.20.20.x network all is allowed?
Andy,
ACL is state-less. It's not FIREWALL. You have to think about the direction you apply. Yes, 3 remote subnets can access to 10.20.20.x. Because you didn't have inbound ACL to block them. What happens if you do that. Connecting from 10.20.20.x to 192.168.X.y network may not work when packets routed back from 3 remote subnets.
My 2 cents
Toshi
This makes a lot more sense. I've tested and all 3 subnets can access this, however a new subnet 192.168.90.x can't?
Also I was to restrict access would I simple add a new access list to fa0/1 inbound?
Andy,
New remote subnet 192.168.90.x added? Well,let's modify ACL to allow them.
You want to restrict accessing by using inbound ACL. Well, let's test it out. You will see what's going on.
Toshi
What I mean is before adding the inbound acl 192.168.90.x should have access to 10.20.20.x as there are no acl's inbound to stop this? Well it can't, but the 3subnets can.
Andy,
We are now in page number2 for this thread. (grin) What I told you is that you have assigned the outbound ACL. let's modify things as follows:
ip access-list extended MYACL1
permit ip 10.20.20.0 0.0.0.255 192.168.28.0 0.0.0.255 log
permit ip 10.20.20.0 0.0.0.255 192.168.20.0 0.0.0.255 log
permit ip 10.20.20.0 0.0.0.255 192.168.90.0 0.0.0.255 log
deny ip any any log
Like I said, It's not a firewall. Just think about how the packets go back and forth.
Toshi
Just to add the how the communication work
when you access the remote network 192.168.x.y. through 10.20.20.x
packet will be source : 10.20.20.x and destination will be : 192.168.x.y
this will reach the destination now its time to respond through host in 192.168.x.y to 10.20.20.x the respond packet will be source : 192.168.x.y and destination will be : 10.20.20.x
so this is how the process goes.
