ACL help
siscisco05
I have an extended ACL configured on a router denying traffic from a host through port 80. The problem is it is not being applied to the interface. How can I bound this ACL to an interface? Is there any documentation out there that goes over these steps?
thanks
Jon Marshall
You apply an acl to an interface with the following
int fa0/1
ip access-group "acl_name" in|out
Jon
Ok, thanks for the help. Is there a way to verify that it is attached to the interface?
Richard Burts
Sean
If you have configured the access list then the way that you apply it (or bind it) to the interface is with the command ip access-group in|out
If you are looking for documentation you could start with this link:
http://www.cisco.com/en/US/products/ps6350/products_configuration_guide_chapter09186a0080430e5b.html#wp1066643
[edit] seeing your response - if you want to check that the ACL is bound to the interface I would suggest doing show ip interface . This output shows any inbound or outbound access lists that have been configured.
Rick
Rick
