ACL inside VPN
sergo777
Level 2
Level 2
Hi There,
I need to run only specific traffic inside VPN (for example HTTPS and ICMP). How to do it? i couldn't find solution. This one, looks like different:
IPsec Data Plane Configuration Guide, Cisco IOS Release 15M&T - Crypto Access Check on Clear-Text Packets [Support] - Cisco
its standard IPSec between Cisco Router and Sophos.
thanks
2 Accepted Solutions
set ip access-group in/out under the crypto map.
this can be used to filter the traffic encrypt by ipsec.
Thanks!
like that?
crypto map vpnmap 10 ipsec-isakmp
 set peer 192.168.2.1
 set transform-set trans1
 set ip access-group 151 in
 set ip access-group 161 out
 match address 101
access-list 101 permit ip 10.1.1.0 0.0.0.255 10.1.2.0 0.0.0.255
access-list 150 permit udp host 192.168.2.1 eq 500 host 192.168.1.1 eq 500
access-list 150 permit esp host 192.168.2.1 host 192.168.1.1
access-list 151 permit tcp 10.1.2.0 0.0.0.255 eq telnet 10.1.1.0 0.0.0.255
access-list 151 permit tcp 10.1.2.0 0.0.0.255 10.1.1.0 0.0.0.255 eq telnet
