ACL issue - All traffic getting block in error
eagletec1
Hi all,
I'm having difficultly with the below ACL. No matter which interface (dailer or fa) I apply it to all IP traffic gets blocked. I must be missing something as I tried this ACL on 3 different 800 series routers all with the same results. Any help would be greatly appreciated.
I'm testing it from a laptop with the IP of 10.1.3.253 and with the ACL off all traffic flows perfectly.
Louise
ip access-list extended QQQ_ACL
    permit ip object-group QQQ_Management_Group any
    permit tcp object-group QQQ_Users_Group any eq smtp pop3 993 995 3389 5900 telnet ftp ftp-data domain
    permit udp object-group QQQ_Users_Group any eq domain ntp rip tftp
    permit tcp 192.168.2.0 0.0.0.255 any eq www 443 8080 5190 1863 time-range QQQ_Control
    permit tcp 192.168.3.0 0.0.0.255 any eq www 443 8080 5190 1863 time-range QQQ_Control
    permit tcp 192.168.4.0 0.0.0.255 any eq www 443 8080 5190 1863 time-range QQQ_Control
object-group network QQQ_Management_Group
range 192.168.0.1 192.168.0.25
range 192.168.0.200 192.168.0.254
192.168.1.0 255.255.255.0
192.168.4.0 255.255.255.0
192.168.5.0 255.255.255.0
192.168.7.0 255.255.255.0
192.168.8.0 255.255.255.0
192.168.10.0 255.255.255.0
10.1.0.0 255.255.0.0
object-group network QQQ_Users_Group
range 192.168.0.26 192.168.0.199
192.168.2.0 255.255.255.0
192.168.3.0 255.255.255.0
192.168.6.0 255.255.255.0
periodic weekdays 19:00 to 22:00
2 Accepted Solutions
When Laptop on VLAN 10, you tested with this configuration?:
IP: 10.1.3.253
Mask: 255.255.255.252
GW: 10.1.3.254
If so there is a mistake:
description QQQ Management users unrestricted
10.1.1.0 255.255.255.252
10.1.2.0 255.255.255.252
10.1.3.0 255.255.255.252  --> it should be 10.1.3.252 255.255.255.252
10.1.4.0 255.255.255.252
Best regards,
Abzal
cadet alain
Hi Louise,
Taken from your posted config:
so 10.1.3.253 is not part of this subnet
Regards.
Alain
7 Replies 7
Abzal
Level 7
Level 7
Hi Louise,
ACL itself looks fine. Post here full config of router to understand better. What is default gateway for laptop?
Abzal
Best regards,
Abzal
Hi Abzal,
Thanks for your time. Router running config below.
The G/W is 10.1.3.254 (IP of Vlan10), I've also tried changing the G/W on the laptop to 192.168.5.251 (IP of Vlan2) but still no traffic when the ACL is attached to the interface, however both gateways work perfectly with no ACL. The basic setup is restricted users on networks 192.168.0.0/24 (only some users to be restricted), 192.168.2.0/24 (all users), 192.168.3.0/24 (all users) and 192.168.6.254 (all users). The users are to have email access all the time but only web services between 7pm - 10pm hence the time range. This 800 (888-K9) series router is one of three routers all connecting back to Vlan 2 (195.168.5.0/24) which in turn connects to the company gateway 192.168.0.254/24. All the networks that are to have restricted traffic connect to these three routers before being forwarded to the company gateway.
Louise
Current configuration : 10700 bytes
! No configuration change since last restart
version 15.0
no service pad
hostname QQQ_Router_5
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
enable secret 5 $1$v6zH$fsvi2qe/QGLti9dtE014h.
no aaa new-model
memory-size iomem 10
clock timezone Magadan 11
crypto pki trustpoint TP-self-signed-2051046481
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-2051046481
revocation-check none
rsakeypair TP-self-signed-2051046481
crypto pki certificate chain TP-self-signed-2051046481
certificate self-signed 01
  3082024E 308201B7 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 32303531 30343634 3831301E 170D3132 31313134 30363035
  35335A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D32 30353130
  34363438 3130819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  81009D28 3398110E 2F908631 8E027955 52824BE9 02D6BD6D 20689F4E 4D88606A
  31239BD3 E5F5D5C1 DE2D87F3 760CDCB2 AB30070D C4D345CD E40BEE45 97240876
  C5B7FE5F 3895DB54 B7050823 D16AC1E1 259DA16E 5154E82C 5943B04F 9D1C2604
  CB58C2A9 E8943DEC 96565917 F52693A3 6890CC31 FDB4DA76 CAE5B60F 7235751B
  93E70203 010001A3 76307430 0F060355 1D130101 FF040530 030101FF 30210603
  551D1104 1A301882 16515151 5F526F75 7465725F 352E5151 512E4C6F 63616C30
  1F060355 1D230418 30168014 515DEF05 D8C441BF 81D86AA0 5B0D329D 47F9D81E
  301D0603 551D0E04 16041451 5DEF05D8 C441BF81 D86AA05B 0D329D47 F9D81E30
  0D06092A 864886F7 0D010104 05000381 81006A30 270AC49B 17C7F44D 4A7C38B2
  FCBF215A F858D02E BBD76DD6 51A9BE07 C772FD05 49EE1D0E F6803EDB 2C036BD3
  AC718ABC A82FC82A 38C3805A AC601943 B8077AD7 0C5114FD C69501CB 7938716B
  BE78CDEF 1DF683BE 1ECA1E07 A0F45E0A 4DD4BDA2 09141EB8 ABDC2483 CEEC4013
  54A68CF2 77D3F45F 9E919F20 BC03DAB3 413C
        quit
ip source-route
ip nbar port-map custom-02 udp 20408 20409 20410
ip nbar port-map custom-01 tcp 20408 20409 20410
ip cef
ip domain name QQQ.Local
ip name-server 192.168.0.6
ip name-server 202.1.161.36
ip name-server 202.1.161.37
no ipv6 cef
license udi pid CISCO888-K9 sn FGL161520EM
object-group network QQQ.Local
description QQQ Doamin Group
192.168.0.0 255.255.255.0
description QQQ users restricted
username cpadmin privilege 15 secret 5 $1$VH0.$ZduqkkDaAcdfqD9M1ojJz.
controller DSL 0
mode atm
line-term co
line-mode 4-wire enhanced
dsl-mode shdsl symmetric annex B
ignore-error-duration 30
class-map match-any QQQ_QOS
match protocol sip
match protocol custom-01
match protocol custom-02
match protocol vnc
policy-map CCP-QoS-Policy-1
class QQQ_QOS
  set dscp ef
   police cir 60000000
     conform-action set-dscp-transmit 46
     exceed-action drop
zone security Inside
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface ATM0
no ip address
shutdown
no atm ilmi-keepalive
interface ATM0.1 point-to-point
description PPP_To_Ranandi(Not in Use)
ip address 10.1.10.254 255.255.255.252
ip access-group 101 in
ip access-group 101 out
ip mask-reply
ip nat inside
ip virtual-reassembly
pvc 8/35
  encapsulation aal5snap
interface FastEthernet0
description VLAN1
interface FastEthernet1
description VLAN1
interface FastEthernet2
description VLAN10
switchport access vlan 10
interface FastEthernet3
description VLAN2
switchport access vlan 2
interface Vlan1
description QQQ_Management_LAN
ip address 192.168.10.251 255.255.255.0
ip mask-reply
ip directed-broadcast
ip flow ingress
ip nat inside
zone-member security Inside
ip tcp adjust-mss 1452
interface Vlan2
description QQQ_WAN_To_LAN
ip address 192.168.5.251 255.255.255.0
ip access-group QQQ_ACL out
ip mask-reply
ip flow ingress
ip nat inside
interface Vlan10
description WAN_To_Ranandi_Via_NB724
ip address 10.1.3.254 255.255.255.252
ip mask-reply
ip flow ingress
ip nat inside
router rip
version 2
passive-interface ATM0
passive-interface ATM0.1
passive-interface BRI0
network 10.0.0.0
network 192.168.0.0
network 192.168.1.0
network 192.168.2.0
network 192.168.3.0
network 192.168.4.0
network 192.168.5.0
network 192.168.6.0
network 192.168.7.0
network 192.168.8.0
network 192.168.10.0
no auto-summary
ip forward-protocol nd
ip http server
ip http access-class 23
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface ATM0.1 overload
ip route 0.0.0.0 0.0.0.0 Vlan2 permanent
ip route 10.1.3.0 255.255.255.252 Vlan10 permanent
ip route 192.168.0.0 255.255.255.0 Vlan2 permanent
ip route 192.168.5.0 255.255.255.0 Vlan2 permanent
ip route 192.168.10.0 255.255.255.0 Vlan1 permanent
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.0.0.0 0.255.255.255
access-list 1 permit 10.1.0.0 0.0.255.255
access-list 23 remark CCP_ACL Category=16
access-list 23 remark WAN_One
access-list 23 permit 10.1.1.0 0.0.0.255
access-list 23 remark WAN_Two
access-list 23 permit 10.1.2.0 0.0.0.255
access-list 23 remark China_Town_VLAN1
access-list 23 permit 192.168.0.0 0.0.0.255
access-list 23 remark Vavaya_Ridge_VLAN1
access-list 23 permit 192.168.1.0 0.0.0.255
access-list 23 remark Mbokonavera_VLAN1
access-list 23 permit 192.168.2.0 0.0.0.255
access-list 23 remark Ranandi_VLAN1
access-list 23 permit 192.168.3.0 0.0.0.255
access-list 23 remark VOIP_VLAN2
access-list 23 permit 192.168.4.0 0.0.0.255
access-list 23 remark China_Town_VLAN3 (WAN)
access-list 23 permit 192.168.5.0 0.0.0.255
access-list 23 remark Vavaya_Ridge_VLAN2
access-list 23 permit 192.168.6.0 0.0.0.255
access-list 23 remark Mbokonavera_VLAN2
access-list 23 permit 192.168.7.0 0.0.0.255
access-list 23 remark Ranandi_VLAN2
access-list 23 permit 192.168.8.0 0.0.0.255
access-list 100 remark Any_Any
access-list 100 remark CCP_ACL Category=128
access-list 100 permit ip object-group QQQ.Local any
access-list 101 remark QQQ_Extended_ACL
access-list 101 remark CCP_ACL Category=1
access-list 101 remark Auto generated by CCP for NTP (123) 203.12.160.2
access-list 101 permit udp host 203.12.160.2 eq ntp host 10.1.10.254 eq ntp
access-list 101 permit udp host 203.12.160.2 eq ntp host 10.1.3.254 eq ntp
access-list 101 remark WAN_One
access-list 101 permit ip 10.1.1.0 0.0.0.255 any
access-list 101 remark Wan_Two
access-list 101 permit ip 10.1.2.0 0.0.0.255 any
access-list 101 remark Domain_Server_Any_Any
access-list 101 permit ip host 192.168.0.6 any
access-list 101 remark China_Town_VLan1
access-list 101 permit ip 192.168.0.0 0.0.0.255 any
access-list 101 remark Vavaya_Ridge_VLAN1
access-list 101 permit ip 192.168.1.0 0.0.0.255 any
access-list 101 remark Mbokonavera_VLAN1
access-list 101 permit ip 192.168.2.0 0.0.0.255 any
access-list 101 remark Ranandi_VLAN1
access-list 101 permit ip 192.168.3.0 0.0.0.255 any
access-list 101 remark VOIP_VLAN2
access-list 101 permit ip 192.168.4.0 0.0.0.255 any
access-list 101 remark China_Town_VLan3 (WAN)
access-list 101 permit ip 192.168.5.0 0.0.0.255 any
access-list 101 remark Vavaya_Ridge_VLAN2
access-list 101 permit ip 192.168.6.0 0.0.0.255 any
access-list 101 remark Mbokonavera_VLAN2
access-list 101 permit ip 192.168.7.0 0.0.0.255 any
access-list 101 remark Ranandi_VLAN2
access-list 101 permit ip 192.168.8.0 0.0.0.255 any
access-list 102 remark CCP_ACL Category=1
access-list 102 permit udp host 202.1.161.37 eq domain any
access-list 102 permit udp host 202.1.161.36 eq domain any
access-list 102 permit udp host 192.168.0.6 eq domain any
access-list 102 remark WAN_One
access-list 102 permit ip 10.1.1.0 0.0.0.255 any
access-list 102 remark WAN_Two
access-list 102 permit ip 10.1.2.0 0.0.0.255 any
access-list 102 remark China_Town_VLAN1
access-list 102 permit ip 192.168.0.0 0.0.0.255 any
access-list 102 remark Vavaya_Ridge_VLAN1
access-list 102 permit ip 192.168.1.0 0.0.0.255 any
access-list 102 remark Mbokonavera_VLAN1
access-list 102 permit ip 192.168.2.0 0.0.0.255 any
access-list 102 remark Ranandi_VLAN1
access-list 102 permit ip 192.168.3.0 0.0.0.255 any
access-list 102 remark VOIP_VLAN2
access-list 102 permit ip 192.168.4.0 0.0.0.255 any
access-list 102 remark China_Town_VLAN3 (WAN)
access-list 102 permit ip 192.168.5.0 0.0.0.255 any
access-list 102 remark Vavaya_Ridge_VLAN2
access-list 102 permit ip 192.168.6.0 0.0.0.255 any
access-list 102 permit ip 192.168.7.0 0.0.0.255 any
access-list 102 remark Ranandi_VLAN2
access-list 102 permit ip 192.168.8.0 0.0.0.255 any
control-plane
banner exec ^C^C
banner login ^CWelcome to QQQ Router 5
* Authorised access ONLY. Unauthorised access is forbidden *
************************************************************^C
banner motd ^C^C
line con 0
login local
no modem enable
line aux 0
line vty 0 4
access-class 23 in
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
ntp update-calendar
ntp server 203.12.160.2 prefer
periodic daily 19:00 to 22:00
end
Ok, thank you for requested info. Now how your network is organized. How is your network getting access to the Internet?
What is gateway for it? Is it Vlan2 or ATM0.1? I cannot understand it. On which VLAN your testing laptop is?
Diagram of network topolgy will be very useful.
Abzal
Best regards,
Abzal
IP: 10.1.3.253
GW: 10.1.3.254
Best regards,
Abzal
Thanks guys, this was driving me crazy, such a small simple mistake. That’s why it always pays to get a third person to look at your work. Thanks again
Louise
cadet alain
Hi Louise,
Regards.
Alain
Louise
