ACL ISSUE
wajid dabir
Level 3
Level 3
i have cisco 4948 as a core switch.it has 2 VLAN.VLAN 1:172.23.0.0/23 $ VLAN 2: 172.23.4.0/23.my all servers is in VLAN 1 and my internet is also in the same VLAN.
1.i want vlan 1 should not communicate with vlan 2 except  2 host.
2.i want vlan 2 user should communicate with only some server of VLAN 1 and internet.
I configured following ACL on VLAN 1 and for VLAN 2...but it is not working.kindly help me to solve this issue.
interface Vlan1
ip access-group DENY in
ip address 172.25.0.10 255.255.252.0 ! interface Vlan2
ip access-group allow-RBC in
ip address 172.25.4.5 255.255.252.0 ip helper-address 172.23.0.70 ! ip route 0.0.0.0 0.0.0.0 172.23.0.70 ip http server ! ip access-list extended ALLOW-RBC permit ip any host 172.23.0.20 permit ip any host 172.23.0.54 permit ip any host 172.23.0.69 permit ip any host 172.23.0.65 permit ip any host 172.23.0.70 permit ip any host 172.23.0.14 permit ip any host 172.23.0.26 permit ip any host 172.23.0.25 permit ip any host 172.23.0.11 permit ip any host 172.23.0.12 permit ip any host 172.23.0.71 permit ip any host 172.23.0.02 permit ip any host 172.23.0.3 permit ip any host 172.23.0.5 deny   ip any any permit ip any host 172.23.0.10 ip access-list extended DENY deny   ip 172.23.0.0 0.0.3.255 172.23.4.0 0.0.3.255 permit ip 172.23.0.0 0.0.3.255 any !
12 Replies 12
Julio Carvajal
Ip access-list ext Vlan1-in
permit ip any host x.x.x.x ( First Vlan 2 host)
permit ip any host y.y.y.y ( Second Vlan 2 host)
Deny ip any any
Ip access-list ex Vlan2-in
permit ip any host z.z.z.z ( Host vlan1)
deny ip any  172.23.0.0 0.0.1.255
permit ip any any
Interface vlan 1
ip access-group Vlan1-in in
Interface vlan 2
ip access-group Vlan2-in in
Remember to rate all of the helpful posts
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Thanks sir for your reply...
in 1st case i mean 2 user of VLAN 1 should communicate with any user of VLAN 2.
and how u calculate
Hello Wajid,
1 case
permit ip  host x.x.x.x ( First Vlan 1 host) 172.25.4.0 0.0.3.255
permit ip  host y.y.y.y ( Second Vlan1 host)  172.25.4.0 0.0.3.255
Deny ip any any
I calculated wrong , It was to late lastnight ( I should have been sleeping )
It should be
deny ip any  172.23.0.0 0.0.3.255
permit ip any any
Hope that I could help
Julio Carvajal
Dear Sir,
case 2 is not working....
Vlan 2 user not communicating with permit vlan 1 host...
Do it like that
permit ip host x.x.x.x (vlan 2 )host z.z.z.z ( Host vlan1)
deny ip 172.25.4.0 0.0.3.255 172.235.0.0 0.0.3.255
permit ip any any
** Do Rate All Helpful Posts***
Jawad
Mukhtar,
i dont think your suggested ACL is correct,because we want appox.70 user from VLAN2 to do communicate with vlan 1 some servers.it makes long ACL for it.
Wajid Do it in your best way possible it was example for you.
Thanks.
Jawad
So case 1 is working,
What is case 2 , can you explain it once again????
Just to be sure,
Julio Carvajal
case 2 is:VLAN 2 user should communicate with some server which is in VLAN 1 not to other machines of vlan 1.
but after issuing 1st ACL in vlan 1, vlan 2 user only communicating with the permitted user in ACL vlan1-in.
Vlan 2 user means just one IP.....
permit ip host x.x.x.x ( Vlan 2 host)  host z.z.z.z ( Host vlan1)
permit ip any any
That should to it, it will only allow communication from one host to one server on the other vlan,
Julio Carvajal
no dear,i mean all users of vlan2 should communicate with some server which is in VLAN1....
case 2 is:VLAN 2 user (Singular) should communicate with some server which is in VLAN 1 not to other machines of vlan 1.
Man I am confused.........
Ok here it goes for the last time
permit ip host x.x.x.x ( Vlan 2 host) 172.23.0.0 0.0.1.255
permit ip any any
That's what you are looking for
Julio Carvajal
