ACL sequnce number not in order
sj1031
Hi all
i notice my ACL have sequnce number that is not in order, i thought the sequnce number should automagically goes in order, exmplae 10, 20, 30 ....... etc
Switch#sh access-lists
Standard IP access list 99
    30 permit 172.18.1.2 (328056 matches)
    10 permit 172.18.1.3 (417138 matches)
    20 permit 172.18.1.4 (875236 matches)
13 Replies 13
Reza Sharifi
That is correct. The ACL sequence number should be in order (10, 20, 30, etc..)
It maybe a bug the IOS you are running.
Julio E. Moisa
Try to use named ACL instead numbered ACL, for example:
ip access-list standard MY-NETWORKS
permit 1.1.1.0 0.0.0.255
permit host 2.2.2.2
permit 3.3.3.3 0.0.0.0
Add a new entry and please verify again.  Also you could try using:
ip access-list standard 99
10 permit 1.1.1.0 0.0.0.255
20 permit host 2.2.2.2
30 permit 3.3.3.3 0.0.0.0
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Brian M
I have this same problem and I've tested it on two versions; IOS-15.6.2 and XE-16.07.
If I enter this:
ip access-list standard TEST
permit 10.128.2.94
permit 10.190.9.100
permit 10.216.190.46
I end up with this
Standard IP access list TEST
30 permit 10.216.190.46
10 permit 10.128.2.94
20 permit 10.190.9.100
A little more detail:
  • Its always out of order in the same way on the different devices.
  • Extended ACLs don't seem to have this issue.
  • It only does this when I enter a host address (as opposed to subnet/wildcard).
  • If enter a subnet & wildcard it's always in the correct order (the order I added it).
  • Even if I enter it as permit host x.x.x.x , it'll still go out-of-order.
Estimated,
Please read the last reply from this post https://supportforums.cisco.com/t5/lan-switching-and-routing/access-list-wrong-order/td-p/3070419
Do not forget to rate useful answers.
Best Regards,
@Diana Karolina Rojas wrote:
Estimated,
Best Regards,
That definitely answer is, Thank you!!
Hi Brian, did you solve this one?
post this in separate post.
Then sequence-numbers are only visible in a "show access-list" and not in a show run. If you want to add a line at a specific position, just take an unused sequence-number and add the new line. It will be added at the right place:
c1841#sh access-lists
Extended IP access list TEST
    10 permit icmp any any (5 matches)
    20 permit udp any any
    30 permit esp any any
c1841(config)#ip access-list ext TEST
c1841(config-ext-nacl)#15 permit tcp any any
c1841(config-ext-nacl)#do sh ip access-list TEST
You can also renumber your ACLs if you want to.
c1841(config)#ip access-list resequence TEST 50 20
c1841(config)#
c1841(config)#do sh ip access-list TEST
    50 permit icmp any any
    70 permit tcp any any
    90 permit udp any any
    110 permit esp any any
c1841(config)#
Hello
ip access-list resequence 99 10 10
That should put them in order starting with the first ace statement starting at 10 and incrementing by 10
res
Paul
Kind Regards
Paul
@paul driver Thank you! That works!
This should be marked as an accepted solution!
steliosandreou
Any solution to this?
If you read this discussion there is a very excellent explanation of this behavior by Peter Paluch.
His point is that this is an intended behavior, it is not a bug/defect and it does not need to be fixed.
Rick
