ACL syntax question
Venison Mogambi
Level 2
Level 2
I have a simple question about building extended ACLs. If I want to match on more than one non-contiguous port, can I just list them out in the ACL? For example, if I wanted to match on ports 80, 443 and 22, can I do it like this:
ip access-list extended Test
permit tcp any host 10.10.10.1 eq 80 443 22
And if I can do that, what's the limit on how many individual ports I can include? And does it match any or all? I'm guessing it will match on any of them.
Thanks.
Venison,
It allows you to open ports to that host, but not the whole range. It's the equivalent of an OR operation and lets you consolidate your acls.
permit tcp any host 10.10.10.1 eq 443 7001
Same as:
permit tcp any host 10.10.10.1 eq 7001
HTH,
John
HTH, John *** Please rate all useful posts ***
Giuseppe Larosa
Hello Venison,
the eq port operator supports a single value so  you need multiple statements to match on multiple TCP ports. The range operator allows for an interval but it would permit all values in range.
"Compares source or destination ports. Possible operands include lt (less than), gt (greater than), eq (equal), neq (not equal), and range (inclusive range).
If the operator is positioned after the source and source-wildcard, it must match the source port.
If the operator is positioned after the destination and destination-wildcard, it must match the destination port.
>> The range operator requires two port numbers. All other operators require one port number."
see
http://www.cisco.com/en/US/docs/ios-xml/ios/security/a1/sec-cr-a2.html#GUID-9EA733A3-1788-4882-B8C3-AB0A2949120C
Hope to help
Giuseppe
Hi Giuseppe,
Thanks for the reply. But if the eq operator only allows a single port number, why does it allow me to enter multiple port numbers. For example, see the output below. I created this on an operational router. It allowed me to enter two discontiguous port numbers:
router(config)#ip access-list extended Test
router(config-ext-nacl)#permit tcp any host 10.10.10.1 eq 443 7001
router#sh ip access-lists Test
Extended IP access list Test
    10 permit tcp any host 10.10.10.1 eq 443 7001
Any ideas?
Thanks.
Venison,
Same as:
HTH,
John
Excellent! That's excatly what I needed it for.
Thanks very much.
