4500 interface description: FIXME
Rick Morris
Level 11
Level 11
Anyone ever see this before?
I was told that this is due to an issue on the interface like errors or something else.  I have never seen it before and wondered if that was true.
This interface is on the SUP
mcptl01-res-01#show int gig 1/2
GigabitEthernet1/2 is down, line protocol is down (notconnect)
   Hardware is Gigabit Ethernet Port, address is 000f.23ba.8701 (bia 000f.23ba.8701)
  Description: FIXME
   MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
   Keepalive set (10 sec)
   Full-duplex, Auto-speed, link type is auto, media type is 1000BaseSX
   input flow-control is off, output flow-control is off
   Last input 06:31:21, output never, output hang never
   Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
   Queueing strategy: fifo
   Output queue: 0/40 (size/max)
      30330428078 packets input, 11091995606121 bytes, 0 no buffer
      Received 111628090 broadcasts (78277429 multicasts)
      51392668150 packets output, 46144143931460 bytes, 0 underruns
      0 output errors, 0 collisions, 1 interface resets
      0 lost carrier, 0 no carrier
mcptl01-res-01#
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-IPBASEK9-M), Version 12.2(53)SG2, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Tue 16-Mar-10 00:30 by prod_rel_team
Image text-base: 0x10000000, data-base: 0x11D24284
ROM: 12.2(20r)EW1
Dagobah Revision 226, Swamp Revision 34
mcptl01-res-01 uptime is 45 weeks, 6 days, 20 hours, 51 minutes
System restarted at 14:26:38 EDT Wed Jun 15 2011
System image file is "bootflash:cat4500-ipbasek9-mz.122-53.SG2.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco WS-C4506 (MPC8245) processor (revision 10) with 262144K bytes of memory.
Processor board ID FOX080309LX
MPC8245 CPU at 266Mhz, Supervisor II+
Last reset from PowerUp
1 Virtual Ethernet interface
144 FastEthernet interfaces
2 Gigabit Ethernet interfaces
511K bytes of non-volatile configuration memory.
mcptl01-res-01>sh mod
Chassis Type : WS-C4506
Power consumed by backplane : 0 Watts
Mod Ports Card Type                              Model              Serial No.
1     2  Supervisor II+ 1000BaseX (GBIC)        WS-X4013+          JAE0923E4LF
2    48  10/100BaseTX (RJ45)V                   WS-X4148-RJ45V     JAE0814B7CD
3    48  10/100BaseTX (RJ45)V                   WS-X4148-RJ45V     JAE0814BGB5
4    48  10/100BaseTX (RJ45)V                   WS-X4148-RJ45V     JAE0814BG9U
M MAC addresses                    Hw  Fw           Sw               Status
1 000f.23ba.8700 to 000f.23ba.8701 4.0 12.2(20r)EW1 12.2(53)SG2      Ok
2 000f.907e.3b10 to 000f.907e.3b3f 2.7                               Ok
3 000f.907e.6840 to 000f.907e.686f 2.7                               Ok
4 000f.907e.65a0 to 000f.907e.65cf 2.7                               Ok
mcptl01-res-01>
6 Replies 6
Edison Ortiz
Rick,
I couldn't find anything internally which refers to that behavior.
I believe someone manually entered that description or done via script from a management system.
The switch itself won't apply the description based on port condition.
Edison
Edison and Glen,
I knew I was not going crazy but needed to check for my own sanity.  There was a person here who insisted and I just had a hard time believing, but I must admit there was some room for doubt.  It just did not make any sense and I could find nothing to the effect.
Thanks!
Strongly recommend you never accept food from this person.    -Ed
glen.grant
  That field is just a manual description field that you have enter via CLI.  Think someone was just trying to be funny  or they were using it as an indicator that the port was faulty .
fb_webuser
Level 11
Level 11
do like this:
NJ-R1#config t
Enter configuration commands, one per line. End with CNTL/Z.
NJ-R1(config)#int gig 1/2
NJ-R1(config-if)#desc FIXED
NJ-R1(config-if)#
and you should be OK!!!!!
Posted by WebUser Neeraj Jagga from Cisco Support Community App
LOL! Well, you could always do a "show run int g1/2" to see if the description is actually in the configuration. I would think a "show int g1/2 descr" would show you the same thing.
HTH, John *** Please rate all useful posts ***
