ACL
alsayed
Level 7
Level 7
Why Like This?
access-list Mail-ACL-out extended permit tcp host 209.165.200.231 eq pop3 any
and Not Like This?
access-list Mail-ACL-out extended permit tcp host 209.165.200.231 any eq pop3
What's The Difference?
Thanks a Lot
Jon Marshall
Ali
means allow the host/server 209.165.200.31 to send TCP packets with the source port of pop3 to any destination address on any address
means allow the host/server 209.165.200.31 to send TCP packets with a source port of any to any destination address with a destination port of pop3.
If 209.165.200.231 is your POP server then the first one is probably what you want.
Jon
Istvan_Rabai
Level 11
Level 11
Hi Ali,
The generalized format of tcp access-lists is the following:
permit | deny tcp (source address or address range) [source port or port range] (destination address or address range) [destination port or port range] [options]
Cheers:
Istvan
