ACLs
david foley
Trying to Set up ACL's
I have 3 Routers with Pcs on Each, On R1 Deny PC1 to PC3, And on R2 for PC2  only allow www permit nothing else
So far i have this,,
on Router 3
ip access-list standard no_access
deny PC1 IP address Wild Card
Permit any
access-list 101 permit tcp PC2 IP address - Wild Card any eq 80
access-list 101 permit ip any any
ip access-group 101 in
This Seems to be Over Writing the Standard ACL,, and the PC2 still can ping by ICMP. and Telnet do i need to block all them or is their a Code which allow me to enter in and all ports are block bar http  ?
11 Replies 11
Collin Clark
It's not overwriting the standard ACL. You are applying ACL 101 to the interface not the standard ACL. You can only apply one ACL to an interface per direction. You will need to add (and adjust) the standard ACL to ACL 101 to accomplish the filtering you are looking for.
I have
Router(config)#access-list 101 deny tcp 172.190.0.64 0.0.0.28 any eq www
Router(config)#access-list 101 deny tcp 172.190.0.64 0.0.0.28 any eq ftp
Router(config)#access-list 101 deny tcp 172.190.0.64 0.0.0.28 any eq telnet
Router(config)#access-list 101 deny tcp 172.190.0.64 0.0.0.28 any eq smtp
Router(config)#access-list 101 deny tcp 172.190.0.32 0.0.0.28 any eq smtp
Router(config)#access-list 101 deny tcp 172.190.0.32 0.0.0.28 any eq telnet
Router(config)#access-list 101 deny tcp 172.190.0.32 0.0.0.28 any eq ftp
Router(config)#access-list 101 permit tcp 172.190.0.32 0.0.0.28 any eq www
Router(config)#access-list 101 permit ip any any
Router(config)#int fa0/0
Router(config-if)#ip access-group 101 in
Router(config-if)#exit
Router#show access-list 101
Extended IP access list 101
    deny tcp 172.190.0.64 0.0.0.28 any eq 20
    deny tcp 172.190.0.64 0.0.0.28 any eq 465
    deny tcp 172.190.0.32 0.0.0.28 any eq 465
    deny tcp 172.190.0.32 0.0.0.28 any eq 20
    permit ip any any (7 match(es))
And Still able to ping, from both PC's, could my Wild card be wrong, i have 172.190.0.64/27 so thats 224 taken off 252= 28
        172.190.0.32/27 so that again 224 taken off 252 = 28
this is 255-224= 31
Regards.
Alain.
Extended IP access list 102
    deny tcp 172.190.0.64 0.0.0.31 any eq www
    deny tcp 172.190.0.64 0.0.0.31 any eq ftp
    deny tcp 172.190.0.64 0.0.0.31 any eq telnet
    deny tcp 172.190.0.64 0.0.0.31 any eq smtp
    deny tcp 172.190.0.32 0.0.0.31 any eq ftp
    deny tcp 172.190.0.32 0.0.0.31 any eq smtp
    deny tcp 172.190.0.32 0.0.0.31 any eq telnet
    permit tcp 172.190.0.32 0.0.0.31 any eq www
    permit ip any any (11 match(es))
Router#
still pinging.. i cant understand it.... why their able to ping.
Hi David,
all you have in deny statement is different TCP ports , if you need to block ICMP then you need a staement like :-
deny icmp x.x.x.x 0.0.0.31 any
Also, for the access list to work the traffic needs to the go through the that interface, if you are trying to filter traffic inside a vlan then you need diffrent solution.
Manish
hi manisharora111
I have no vlans
just a 3 Routers and 2 Pcs and a Server, i have all the Commands on the Server Router,
trying to Stop the packets going in on FA0/0
K , then you need to add  DENY icmp to block Ping :-
    deny icmp 172.190.0.32 0.0.0.31 any
Router#
Please make sure the deny statement is before the permit any any statement, use line no.'s for that purpose.
Manish
ok, thanks man got it working,
but nothing can ping it now... At lest its a start
Well yes it will block all ping unless you use deny icmp 172.190.0.32 0.0.0.31 network subnetmask instead of any. With any it will block ping to all destinations.
Manish
    deny icmp 172.190.0.32 0.0.0.31 host 172.190.0.78
    deny icmp 172.190.0.64 0.0.0.31 host 172.190.0.78
    permit ip any any
Router#
is this right ?
OK, I got the ACLS working but wanted to check the port 80 on ISP working for Router 2 i blocked every other port.
I added a Server on the ISP, gave it the 172.190.1.2 ip address with  gate way 172.190.1.1 i check the all devices can ping it but and they can.
PC2 cant  which is right. but it give me Time out when i open Web Browser and enter  the servers ip address Which it should allow me to ping the Server by means of Http..
R2#show access-list
Extended IP access list sl_def_acl
     deny tcp any any eq telnet
     deny tcp any any eq www
     deny tcp any any eq 22
     permit tcp any any eq 22
Extended IP access list EXTEND-1
     deny ip 172.190.0.32 0.0.0.31 any
     deny ip 172.190.0.32 0.0.0.31 host 199.1.1.37
     permit ip any any
     permit tcp 172.190.0.32 0.0.0.31 eq www host 199.1.1.37
     deny tcp 172.190.0.32 0.0.0.31 eq ftp host 199.1.1.37
     deny tcp 172.190.0.32 0.0.0.31 eq pop3 host 199.1.1.37
     deny tcp 172.190.0.32 0.0.0.31 eq smtp host 199.1.1.37
     deny icmp 172.190.0.32 0.0.0.31 host 199.1.1.37
     deny tcp 172.190.0.32 0.0.0.31 eq telnet host 199.1.1.37
     permit ip 172.190.0.0 0.0.0.3 any
     permit ip 172.190.0.12 0.0.0.3 any (1 match(es))
     permit ip 172.190.0.4 0.0.0.3 any
     permit ip 172.190.0.16 0.0.0.3 any
     permit ip 172.190.0.20 0.0.0.3 any
     permit ip 172.190.0.80 0.0.0.7 any
     permit ip 172.190.0.72 0.0.0.7 any (22 match(es))
     permit ip 172.190.0.64 0.0.0.31 any (1 match(es))
    permit tcp 172.190.0.32 0.0.0.31 eq www host 172.190.1.2
