ACS
nagalingammk
Level 2
Level 2
there is no log generating for TACACS+ Administration in ACS.
ACS Version: 4.1.1.23
Router Config:
aaa authentication login default group tacacs+ local
aaa authentication login no_tacacs local enable
aaa authentication enable default group tacacs+ enable
aaa authorization exec default group tacacs+ local
aaa authorization network default group tacacs+ local
aaa accounting exec default start-stop group tacacs+
aaa accounting commands 1 default start-stop group tacacs+
aaa accounting commands 7 default start-stop group tacacs+
aaa accounting commands 15 default start-stop group tacacs+
aaa accounting network default start-stop group tacacs+
aaa accounting connection default start-stop group tacacs+
aaa accounting system default start-stop group radius
please advice
mahmoodmkl
Level 11
Level 11
where is the config for the aaa server..?
Make sure that u have proper key configured.
Mahmood
batsoton2006
Community Member
Has the router been configured on the ACS server?
I have the following config on my routers.
aaa authentication fail-message ^CC ***Access Denied*** ^C
aaa authentication password-prompt Local_Password:
aaa authentication username-prompt Local_User:
aaa authorization exec default group tacacs+ if-authenticated
aaa authorization commands 1 default group tacacs+ if-authenticated
aaa authorization commands 15 default group tacacs+ if-authenticated
