add ACL entry 4500
nflnetwork
Hello, how would i verify which ACL is applied to a specific VLAN?
CAT 4500 switch.
12 Replies 12
Jon Marshall
Depends on the type of acl but "sh run" is usually the best way.
Was there something specific you were looking for ?
Jon
ACL attached to VLAN 25
If you mean an acl attached to the L3 interface for vlan 25 then do a "sh run int vlan 25" and look for the "ip access-group ...." configuration command.
Jon
interface Vlan25
ip address 172.16.25.1 255.255.254.0
ip pim sparse-mode
end
What IOS version are you running ?
Jon
your fast lol
its old i can tell you that...i believe it's 3.4.4
If there is no acl applied to the interface then try this command -
"sh run | begin vlan filter"
Jon
comes back empty
As far as I can tell then you don't have an acl applied to that vlan.
Are you sure there is one ?
Jon
ok that makes sense thank.
