Add exxternal IP range
apereira
Visitor
I had a static IP assigned to me by my isp. Which is fine but now I have an ip range of 5 address's i would to add the second static IP and point the type of traffic coming on that to a specific internal server.
Do I need to create another interface called it outside 2 with that static Ip? Not sure
Any help would be great.
I am sure I am way off.
thanks
This is on a cisco asa 5506
Yes, just replicate with what you have for your existing NAT setup.
Jon
14 Replies 14
Jon Marshall
No you don't.
As long as the ISP is routing those new IPs to your ASA then you can just use them in your NAT statements.
Jon
In my nat rules section, i have the following
https traffic being forwarded to internal ip 192.168.1.10 on public ip 45.73.12.42
i want another rule
https traffic being forwarded to internal ip 192.168.1.11 on public ip 45.73.12.43
So just add the NAT rule and obviously allow the access.
There is no requirement for the IP to be assigned to an interface.
Jon
I think i need to create something for public ip 45.73.12.43
right now i only have the ip of the router which is 45.73.12.42, and i have a nat stating all https traffic coming in ip 45.73.12.42 go to internal server 1,
I think i need to create something to tell it that https traffic coming in on ip 45.73.12.43 go to internal server 2.
There is nothing created or defined for ip 45.73.12.43   right now on the firewall.
As I said on the firewall configure a NAT statement for the new IP and update your acl and it should work fine.
Jon
I am really not that familiar on how to do this, quite obvious.
I am on the gui under
Firewall/NAT Rules
I dont really see a place where i can add the external IP,I see add nat rule page.
I see a network object of outside with ip 45.73.12.42, do i create another network object with 45.73.12.43
Jon
apereira
Visitor
I made a mistake in saying the answer is correct.
I am still not getting it to work.
Please see attached snapshots of what i have currently working with https
How do i add a second, I have tried simply using what is currently there and its nor working
I don't use ASDM but you will need to create new objects for the new public and private IPs.
Jon
OK I created the network object for the new ip .43
PLease see attached for what i did and maybe you can see what i am doing wrong
I can't tell from what you have posted as I don't use ASDM.
Can you possibly post the configuration and then I should be able to help you out.
Jon
Sure here you it is
: Saved
: Serial Number: JAD1929028T
: Hardware:   ASA5506, 4096 MB RAM, CPU Atom C2000 series 1250 MHz, 1 CPU (4 cores)
ASA Version 9.4(1)
hostname FW-LNALaval
enable password bgThEbkkouozdXwk encrypted
names
interface GigabitEthernet1/1
 nameif outside
 security-level 0
 ip address 45.73.12.42 255.255.255.248
interface GigabitEthernet1/2
 nameif inside
 security-level 100
 ip address 10.0.0.1 255.255.255.0
interface GigabitEthernet1/2.1
 description DMZ
 vlan 666
 nameif dmz
 security-level 50
 ip address 10.0.1.1 255.255.255.0
interface GigabitEthernet1/3
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/4
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/5
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/6
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/7
 shutdown
 no nameif
 no security-level
 no ip address
interface GigabitEthernet1/8
 shutdown
 no nameif
 no security-level
 no ip address
interface Management1/1
 management-only
 no nameif
 no security-level
 no ip address
ftp mode passive
clock timezone EST -5
clock summer-time EDT recurring
object network obj_any
 subnet 0.0.0.0 0.0.0.0
object network Web-Server
 host 10.0.0.14
object service FTP-SERVICE
 service tcp destination eq ftp
object service FTP-CRUSH_PORTS
 service tcp destination range 2000 2100
object service RDP-SERVICE
 service tcp destination eq 3389
object service rdp-service
 service tcp source eq 3389
object service ftp-crush-ports
 service tcp source range 2000 2100
object service ftp-service
 service tcp source eq ftp
object service SFTP-Service
 service tcp source eq ssh
object service sftp-service
 service tcp destination eq ssh
object service https-service
 service tcp source eq https
object network Prism-Web
 host 10.0.0.16
object service http-service
 service tcp source eq www
object network 43
 host 45.73.12.43
object-group service ftp-crush-group
 service-object object FTP-CRUSH_PORTS
 service-object object FTP-SERVICE
access-list outside_access_in extended permit object RDP-SERVICE any object Web-Server inactive
access-list outside_access_in extended permit object sftp-service any object Web-Server
access-list outside_access_in extended permit object-group ftp-crush-group any object Web-Server inactive
access-list outside_access_in extended permit tcp any object Web-Server eq https
access-list outside_access_in extended permit tcp object 43 object Prism-Web eq www
pager lines 24
logging enable
logging asdm informational
mtu outside 1500
mtu inside 1500
mtu dmz 1500
icmp unreachable rate-limit 1 burst-size 1
no asdm history enable
arp timeout 14400
no arp permit-nonconnected
nat (inside,outside) source static Web-Server interface service any SFTP-Service
nat (inside,outside) source static Web-Server interface service any https-service
nat (inside,outside) source static Web-Server interface service any rdp-service inactive
nat (inside,outside) source static Web-Server interface service any ftp-service inactive
nat (inside,outside) source static Web-Server interface service any ftp-crush-ports inactive
nat (inside,outside) source static Prism-Web 43 destination static 43 43 service any http-service
 nat (any,outside) dynamic interface
access-group outside_access_in in interface outside
route outside 0.0.0.0 0.0.0.0 45.73.12.41 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
user-identity default-domain LOCAL
aaa authentication ssh console LOCAL
aaa authentication http console LOCAL
http server enable
http 10.0.0.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
service sw-reset-button
crypto ipsec security-association pmtu-aging infinite
crypto ca trustpool policy
telnet timeout 5
no ssh stricthostkeycheck
ssh 0.0.0.0 0.0.0.0 inside
ssh timeout 5
ssh key-exchange group dh-group1-sha1
console timeout 0
dhcpd dns 10.0.0.12 8.8.8.8
dhcpd address 10.0.0.50-10.0.0.250 inside
dhcpd dns 10.0.0.12 8.8.8.8 interface inside
dhcpd enable inside
dhcpd address 10.0.1.5-10.0.1.200 dmz
dhcpd enable dmz
threat-detection basic-threat
threat-detection statistics access-list
no threat-detection statistics tcp-intercept
dynamic-access-policy-record DfltAccessPolicy
username admin password a/i69ivzxIdOT6vW encrypted privilege 15
class-map inspection_default
 match default-inspection-traffic
policy-map type inspect dns preset_dns_map
 parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
 class inspection_default
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
Cryptochecksum:c23229a4bd2139f2d4e68d587b46da56
: end
OK what I tried is I added a public server, and then I added a rule in acl and it still doesn't work. Here is my config
: Saved
ASA Version 9.4(1)
names
 nameif outside
 security-level 0
 nameif inside
 security-level 100
 description DMZ
 vlan 666
 nameif dmz
 security-level 50
 shutdown
 no nameif
 no security-level
 no ip address
 shutdown
 no nameif
 no security-level
 no ip address
 shutdown
 no nameif
 no security-level
 no ip address
 shutdown
 no nameif
 no security-level
 no ip address
 shutdown
 no nameif
 no security-level
 no ip address
 shutdown
 no nameif
 no security-level
 no ip address
 management-only
 no nameif
 no security-level
 no ip address
ftp mode passive
 host 10.0.0.14
 host 10.0.0.16
object network 43
 host 45.73.12.43
access-list outside_access_in extended permit object http-service object 43 object Prism-Web
pager lines 24
logging enable
mtu outside 1500
mtu inside 1500
mtu dmz 1500
arp timeout 14400
 nat (inside,outside) static 43
http server enable
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd enable inside
dhcpd enable dmz
 parameters
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect sqlnet
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
Cryptochecksum:fd04a0c347e6f95c2949cf5dd7609488
: end
What is the public IP ?
What is the private IP ?
What ports do you want to allow through ?
Jon
