Add vlan to a trunk port on 3500XL
bridgepatel
I am trying to add a few vlans to a trunk port but it seems like i can only add one vlan. The scenario is i am connecting the switch to a linux box. I have successfully created vlans on the switch. Here is what i am doing.
switch(config-if)#switchport trunk encapsulation dot1q
switch(config-if)#switchport trunk native vlan 11
switch(config-if)#switchport mode trunk
switch(config-if)#switchport trunk allowed vlan add 192
But it only adds one vlan as you can see from the following command
switch#show running-config interface fastEthernet 0/3
Building configuration...
Current configuration:
interface FastEthernet0/3
description "non bridged interface on the xennode"
end
Following are the details of the IOS
IOS (tm) C3500XL Software (C3500XL-C3H2S-M), Version 12.0(5)WC16, RELEASE SOFTWARE (fc1)
Any ideas?
Thanks in advance
Brijesh
2 Accepted Solutions
glen.grant
   Since you did not previously  restrict any vlans across the trunk , all vlans are already allowed across the trunk by default and thus why you cannot add anything because all vlans  are already allowed.
Or in other words if you remove the "add" keyword above you will only allow vlan 192 on the trunk. Then if you want to "add" another vlan to the trunk you should use the "add" keyword.
glen.grant
Thanks  guys
It worked perfectly
