Adding a VTP transperant switch to Switch domain with all VTP Servers
fortis123
Hi All,
My cleint has a n/w in which 10switches are set to VTP server mode (VTP not being used for managing them at all). If I add another switch to the same n/w (to core switch via trunk) with VTP mode as 'TRANSPERANT'transperant will that cause any issues in the live n/w?
Thank you
MS
Collin Clark
Not if it's transparent. Be careful about making it server though, make sure the rev level is lower than the current level.
Hope that helps.
Thank you.. Transperant only. Not going to make it server.
MS
