Interface range command authorization failing
carey.everett
I am currently using TACACS ver 4.0. I wanted to restrict access to certain commands on my switches, ws3560 and 3750 series.
When I add this additional command to enable the restriction.
aaa authorization config-commands
i.e. int range g 0/1- 24
I get a command authorization failed
If I configure a fewer amount of ports
say ports 1-5.
The int range command will pass.
Has anyone else had this problem before.
I am experiencing the very same problem.
IOSs:
c2960-lanbase-mz.122-25.SEE3.bin
c3550-i9q3l2-mz.121-14.EA1a.bin
Did you find a solution?
AL
We really haven't found a solution. We are just doing a few ports at a time, for now.
Thanks for your inquiry.
