DHCP on 2801
lawsonktm
So im new to using cisco routers and i have a basic config for nat but i only can use static ip's at the moment but I enable the dhcp server and set it all up so am i missing something? FYI:
Fa 0/1 = Lan
Fa 0/0 = Wan
Router#show running-config
Building configuration...
Current configuration : 2032 bytes
version 12.4
hostname Router
boot-start-marker
boot-end-marker
no logging console
no aaa new-model
resource policy
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
ip cef
ip inspect name InspectRule icmp
ip inspect name InspectRule tcp
ip inspect name InspectRule udp
ip dhcp relay information option
no ip dhcp use vrf connected
ip dhcp excluded-address 192.168.2.0 192.168.2.100
ip dhcp pool mypool
import all
network 192.168.2.0 255.255.255.0
dns-server 192.168.2.1 8.8.8.8 8.8.4.4
default-router 192.168.2.1
domain-name boucher.local
lease 3
interface FastEthernet0/0
ip address dhcp
ip access-group 101 in
ip inspect InspectRule in
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
ip address 192.168.2.1 255.255.255.0
ip access-group 100 in
ip nat inside
duplex auto
speed auto
interface FastEthernet0/3/0
interface FastEthernet0/3/1
interface FastEthernet0/3/2
interface FastEthernet0/3/3
interface FastEthernet0/3/4
interface FastEthernet0/3/5
interface FastEthernet0/3/6
interface FastEthernet0/3/7
interface FastEthernet0/3/8
interface Vlan1
ip address dhcp
no ip http server
no ip http secure-server
ip nat inside source list 10 interface FastEthernet0/0 overload
access-list 10 permit 192.168.2.0 0.0.0.255
access-list 10 deny any
access-list 100 permit ip 192.168.2.0 0.0.0.255 any
access-list 100 deny ip any any
access-list 101 permit udp any eq bootps any eq bootpc
access-list 101 permit tcp any any
access-list 101 permit udp any any
access-list 101 permit icmp any any echo-reply
access-list 101 permit icmp any any time-exceeded
access-list 101 permit icmp any any unreachable
access-list 101 deny ip any any
control-plane
line con 0
line aux 0
line vty 0 4
login
end
Philip D'Ath
You have not got the router configured to be a DNS server, so change:
to
dns-server 8.8.8.8 8.8.4.4
Philip D'Ath
to
andrewswanson
Level 7
Level 7
Change ACL 100 from:
to:
access-list 100 permit udp any any eq 67
access-list 100 permit udp any any eq 68
This will permit dhcp traffic ingress on F0/1
hth
Andy
when i do these 2 commands it doesn't change the ACL or running config is there something else i need to add to it?
wait no its working now thanks! I dont know which was the correct answer tho because i tried yours and phillip's answer.
