Adding N5K-M1600 Module to Existing Nexus 5010 Switches
David Goldsmith
From the "Cisco Nexus 5000 Series Hardware Installation Guide", I see that for 5010 model switches, "the chassis supports hot swapping of the expansion modules."  This makes me think that if the switch was booted up with a module in place and it then had issues, then I can pull the module out and replace it.
What about a running switch that does not current have an expansion module installed?  Can I simply insert an N5K-M1600 6-port SFP+ module and have it show up in the "show run" output, or does the switch need to be powered off, module inserted and switch rebooted?
http://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus5000/hw/installation/guide/nexus_5000_hig/overview5500.html#pgfId-1261680
Dave
Reza Sharifi
I think your assumption is correct as the documents say:
"The chassis supports hot swapping of the expansion modules"
Which means any expansion module is hot swappable.
But I would still do it in a maintenance window just in case something goes wrong.
Nicolas Rousset
Hello David,
Same situation for me.
I think you have done this operation now.
Is it ok ? Hot swappable without reboot ?
Adrien
Nicolas,
Yes, the module was detected after it was inserted.  We removed the filler plate, inserted the module, saw a couple of log messages on the console, ran "show run" and saw the new module ports listed in the output.
We did not have to reboot the switches.
