Adding Switch to Lan
pcromwell
Level 6
Level 6
We have a new switch that we are trying to put in place of an EOL switch.  The switch has about 6 svi's for the vlans. To minimise downtime, we have added the new switch into the lan alongside the old switch and moved the cables over 1 by 1. This has all worked fine. however when I disconnect the old switch. Everything stops working. I can ping devices from the switch svi. but any device to device pings fail, even though they could be on the same vlan. When I plug the old switch back in it all works again.
I have since then added HSRP and tried a higher priority for the new switch but again it fails. I have to have the old switch be the higher priority for the vlans. I did notice that the new switch was running version 1 of vtp whilst the others were version 2, have since changed this.
It's as if the new switch is not communicating with all the other switches. I am sure I am missing something obvious.
Is anyone able to shed some light on this?
Mark Malone
only guessing here as cant see config but check spanning-tree is not blocking vlans at layer 2
make sure everything is being forwarded on the trunks no vlans missing or being dropped
check correct default-gateway in place
vtp 1 and 2 are backward compatible so that shouldn't be your issue
the arp tables are ok for these ips ?  this is across switches yes not on the same switch in same vlan
Thanks for the reply Mark, I have noticed the new switch is set to PVST and the legacy switches are using mst. So this is prob my problem. should I just set the new switch to use mst like the others?
yes I wouldn't bother trying to migrate between the stp versions its messy and you should only do it if you have to , just pick one type pvst or mst whatever is supported on both make it easier to maintain , that's maybe your issue something at layer 2 being blocked in stp then between the 2 types
