Network Switch Query
ajinkya.jagtap1
Visitor
Hello Team,
I need your support on following points,
Just want to know whether,
1)Cisco switches supports the EAL3 certification.
2)Also does it supports SCP2 and SFTP protocol.
3)CLI over serial RS232 and out of mgmt via additional  100Base-T RJ45
I found that EAL3 certificate is for security/storage products (let me know if i am wrong).
Please share the relevant document/link if you found any.
Georg Pauwen
you are right, EAL3 is a high level security certification; e.g. the MDS9000 is EAL3 is certified. For a current listing of (Cisco) products that are EAL3 certified, you can visit the Common Criteria Portal:
http://www.commoncriteriaportal.org/products/
As for SCP-2 and SFTP support, use the Feature Navigator, as this also depends on the software version in use:
http://cfn.cloudapps.cisco.com/ITDIT/CFN/jsp/by-feature-technology.jsp
RS-232 and out of band management ports also depend on the model, a lot of the newer models (such as the 3750X or the 4500X) do have OOB management ports.
