Adding VLANs to a Nexus Switchport Trunk
joshua.gertig
Hi All,
Quick question. I'm trying to add several VLANs to an uplink port going to one of our floor switch stacks, however it's not letting me add.
Current Interface Config
interface Ethernet1/21
  description Xconn N3 floor switch t4/1/1
  switchport
  switchport mode trunk
  switchport trunk allowed vlan 1,25,50,330-331,337,339,400,555
  switchport trunk allowed vlan add 600,605,666,1112
  channel-group 330 mode active
  no shutdown
Here is what I get when I try to add the VLANs
N7K2# conf t
Enter configuration commands, one per line.  End with CNTL/Z.
N7K2(config)# int e1/21
N7K2(config-if)# switchport trunk allowed vlan add 102-104,109
% Invalid command at '^' marker.
N7K2(config-if)# switchport ?
  host  Set port host
Is the problem that I already have an "add" command in the existing config? And if so, do I need to do a "no switchport trunk allowed vlan add 600,605,666,1112" first and then re-enter the command but add the new vlans?
Ganesh Hariharan
Hello ,
Add VLAN's on interface Port-channel 330
interface port-channel 330
Hope it Helps..
-GI
5 Replies 5
Collin Clark
You should be adding the VLANs on the trunk from the port-channel interface not the physical.
Thanks, I've got it working now
Ganesh Hariharan
Hello ,
Hope it Helps..
-GI
Thanks for this reply!
strange that Cisco doest advise that
joshua.gertig
This did the trick.
Thanks for helping, I'm not quite used to Nexus yet
