Administration network VLAN 1
GaelGiraud
Community Member
I have a question regarding the equipment management network and potential interference with Layer 3 of the switching infrastructure.
At Site 1, I have an MX server that broadcasts DHCP on VLAN 1. It uses a 4G network.
This internet access is solely for retrieving configurations from Cisco Meraki.
Connected to this MX server is a Catalyst C9300-24Y that retrieves its configuration via the 4G network.
This Catalyst is also connected via a dark fiber cable to a second Catalyst server located 2 km away.
Site 2 is the main site, and Site 1 is a new extension.
On the Catalyst at Site 1, I created five Layer 3 interfaces, and I would like the default route for all these interfaces to go to the Catalyst at Site 2 while still retrieving configurations via 4G internet.
Eventually, I plan to upgrade these Catalysts and use the routed IOS ports. VLAN 1 does not flow between Sites 1 and 2.
Can I configure the default route of the switching section at Site 1 to the Catalyst at Site 2 without losing access to VLAN 1 so I can continue to manage my equipment at Site 1 in the dashboard?
To summarize, all my business traffic goes to the Catalyst at Site 2, and dashboard traffic continues to be routed to VLAN 1 as advertised by the MX record.
Best regards,
Gael
aleabrahao
Meraki Community All-Star
Yes, you can configure the Catalyst at Site1 to have a default route pointing to the Catalyst at Site2, keeping VLAN1 local and never forwarding it over dark fiber.
I am not a Cisco employee. My suggestions are based on documentation of Meraki best practices and day-to-day experience.
Please, if this post was useful, leave your kudos and mark it as solved.
aleabrahao
  • Default gateway: When creating the first IPv4 interface on a switch, you will be prompted to enter a default gateway address. This is the next hop IPv4 address of another device on the network, used for any traffic that isn't going to a directly connected subnet or over a static route. This IP address must exist in a subnet with a L3 interface, and will be used for the default route next hop IP address.
https://documentation.meraki.com/Switching/MS_-_Switches/Design_and_Configure/Configuration_Guides/Layer_3_Switching/MS_Layer_3_Switching_and_Routing
aleabrahao
