07-13-2021 05:50 AM
Hi ,
After all these years , is there any implementation of DHCP snooping yet ? I don't see any way to enable it , but access ports in trusted/untrusted state and so on.
I just did a test yesterday and I was able to snoop on DHCP requests made by another client.
Thanks ,
07-13-2021 06:00 AM
Depend, what do you want to use DHCP Snooping for?
If you want to use it for security in conjunction with Dynamic ARP Inspection (DAI), then it’s there, https://documentation.meraki.com/MS/Other_Topics/Dynamic_ARP_Inspection. Beyond that there really isn’t much you can do with DHCP Snooping on the Meraki switches (other than block a rogue DHCP server).
07-13-2021 06:00 AM
You can only block/prevent unwanted dhcp servers.
07-18-2021 10:36 AM
It does support DHCP snooping but the implementation is different.
It does not use a switchport to define where the offer/ack messages can come from but rather the MAC address of the originating server.
And it also has DAI which also relies on the snooping database.
