adsl and vlan help
hmagdy088
hello, im new to ccna .
please any expert help me in this sinario,
router 1721 with one wic-1adsl ,i have adsl conection with irb static ip.
the router connect with mannaged switch through a trunk port.
the switch has 2 vlans one for the static IPs and the other for private lan.
i need the private lan to be able to go to internet please any ideas.
the router configuration is as follows:
Building configuration...
Current configuration : 1272 bytes
! Last configuration change at 16:50:18 pc Fri May 10 2013 by admin
version 12.2
hostname BELCO
boot system tftp c1700-k9o3sy7-mz.122-15.T17.bin 62.x.x.7x
logging queue-limit 100
username admin privilege 15 password 0 HES2010
clock timezone pc 0
ip subnet-zero
ip cef
bridge irb
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 0/35
  encapsulation aal5snap
dsl operating-mode auto
bridge-group 1
interface ATM1
no ip address
shutdown
interface FastEthernet0
no ip address
speed auto
interface FastEthernet0.1
description LAN
encapsulation dot1Q 1 native
ip address 192.168.1.10 255.255.255.0
interface FastEthernet0.2
description WAN
encapsulation dot1Q 2
ip address 62.x.x.7x 255.255.255.248
interface BVI1
mac-address 0000.0cc9.fa98
ip address 10.186.10.106 255.255.255.252
ip classless
ip route 0.0.0.0 0.0.0.0 BVI1
ip http server
ip http authentication local
bridge 1 protocol ieee
bridge 1 route ip
line con 0
speed 115200
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet
no scheduler allocate
end
so vlan2 can go to internet because it has the same subnet with provider but vlan 1 canot go internet.
so how i can make all vlans go internet(the router has only 1 fastethernet port)
thanks in advanced for any help.
5 Replies 5
blau grana
Level 7
Level 7
Hello Hesham,
You need to configure NAT on your router. BVI1 is your WAN interafce?
Try add this to your configuration, if it will work ->
ip access-list extend NAT_ACL
  deny ip 192.168.1.0 0.0.0.255 192.168.1.0 0.0.0.255
  permit ip 192.168.1.0 0.0.0.255 any
  deny ip any any
route-map NAT_MAP
  match ip address NAT_ACL
ip nat inside source route-map NAT_MAP interface BVI1 overload
Let us know if some problem occur.
Best Regards
Please rate all helpful posts and close solved questions
Best Regards Please rate all helpful posts and close solved questions
antonio.guirado
Level 3
Level 3
I agree blau grana but I am confusing because your BVI interface have a private IP address. So if you configure NAT with BVI overload I do not think that it works. You also need "ip nat inside" and "ip nat outside" command:
ip nat inside
exit
interface BVI1
ip nat outside
exit
I suppose you need to define a Loopback interface with a public IP address. Can you send us your how you assign your 62.x.x.7x/255.255.255.248 range?.
thank you guys for help,
but didnt work ,i think i need loopback antonio but im still bigginer and dont know how
can please anyone write me how?.
and the adsl work with me as follow:
one wic-1adsl and the provider give me tow subnets, one for reall IPs 62.135.115.73-78  subnet  255.255.255.248
and i use 73 for the router fastethernet interface.
second is 10.186.10.106  255.255.255.252 for BVI interface
the problem is that the router has one ethernet interface only.
the connection is bridge (irb).
finally i created tow vlans on the switch to be able to use both private and public IPs
but private dont go internet
thanks in advance for any help
OK, so you need to take IP from your public range and assign it to loopback interface.
OR you can use on both subinterfaces private addresses and entire public range use for PAT, statc NAT or what ever, it depends on your reqiurements. How many devices do you have on 62.135.115.72/29 subnet?
If I were you, I would choose second option because in first option you have to lower subnet mask on Fa0.2 from / 29 to /30 which leaves you with only 1 host on this LAN segment!!!
This configuration will ensure that subnet 192.168.1.0/24 will access internet with public IP 62.135.115.72 and subnet 192.168.2.0/24 will access internet with public IP 62.135.115.73.
And you still have 6 more free public IPs for what ever you will need them (static NAT, static portforward. VPN,....)
interface Loopback 72
ip add 62.135.115.72 255.255.255.255
ip nat outside
interface Loopback 73
ip add 62.135.115.73 255.255.255.255
ip nat outside
interface Loopback 74
ip add 62.135.115.74 255.255.255.255
ip nat outside
interface Loopback 75
ip add 62.135.115.75 255.255.255.255
ip nat outside
interface Loopback 76
ip add 62.135.115.76 255.255.255.255
ip nat outside
interface Loopback 77
ip add 62.135.115.77 255.255.255.255
ip nat outside
interface Loopback 78
ip add 62.135.115.78 255.255.255.255
ip nat outside
interface Loopback 79
ip add 62.135.115.79 255.255.255.255
ip nat outside
  description LAN
  ip nat inside
  description WAN
  ip nat inside
  ip address 192.168.2.10 255.255.255.0
ip access-list extend NAT_ACL_1
  deny ip any any
ip access-list extend NAT_ACL_2
  deny ip 192.168.2.0 0.0.0.255 192.168.2.0 0.0.0.255
  permit ip 192.168.2.0 0.0.0.255 any
  deny ip any any
route-map NAT_MAP_1
  match ip address NAT_ACL_1
route-map NAT_MAP_2
  match ip address NAT_ACL_2
ip nat inside source route-map NAT_MAP_1 interface Loopback72 overload
ip nat inside source route-map NAT_MAP_2 interface Loopback73 overload
Best Regards
please do not create duplicate posts
https://supportforums.cisco.com/message/3935556
https://supportforums.cisco.com/thread/2216657
Best Regards
