Advice for Building Small Network Question
I am building a small network environment which will connect to a larger office, scalability is important.  We will begin having about 30 users which will all need VOIP services.  The VOIP services will be hosted by a cloud provider.  My question is as of now I am looking to obtain a Cisco 2921 ISR Router and then a Cisco 2960-X 48Gig POE, and my main question is I am confident the switch can handle the power and operation of the phones but just to make sure I should not run into any problems with the router as far as forwarding the data, correct?  Any other comments or suggestions would be appreciated.
Joe
Leo Laohoo
Duplicate post.
Go HERE.
Hi Leo
Just in case you don't check your private messages can you have a quick look.
Jon
Hi Jon,
I've responded.  :)
