04-12-2016 02:39 AM - edited 03-08-2019 05:19 AM
Hello ,
Any one can advice me what is the ( ip sla monitor ) and where is using .. and can check the ( packet loss , delay ) using it for multi hop .. Thanks in advance
04-12-2016 01:29 PM
What sort of Cisco device do you have?
Do you just want to do monitoring, or do you want it to actually do something?
04-12-2016 01:38 PM
I'm using Cisco and non cisco switched .. I need to check the P.L between them .. Thanks
