Aggregation layer with admin VDC
sblavanya
Level 2
Level 2
Are there any issues using admin / default vdc for aggregation layer ? I have allocated a VDC for core layer, and plan to use the 2 remaining VDC's for future use.. Didnt want to use a VDC seperate for admin.. Do you see any issues with this design?
jbrenesj2
You can safely use the admin VDC for any layer and with any functionality.
If the design allows it and no further use will be given to this VDC, some people like to use it just for allocating interfaces leaving the other VDCs for traffic and protocols but if you plan on using the other VDCs in the future then I dont see any particular problem using it as of now.
- Jorge
jbrenesj2
- Jorge
Thanks Jorge
