cisco switch 3560G slow
sumeet kumar
when i create vlan on this switch, it has delay to ping the virtual interface. and IP routing also doesnot work properly on this switch, i suspect IOS image problem, can some one suggest which IOS version would be great for this switch.
current switch detail.
Switch Ports Model              SW Version            SW Image
*    1 52    WS-C3560G-48TS     12.2(50)SE1           C3560-IPSERVICESK9-M
Regads
Sumeet
Ivan Krimmel
Level 9
Level 9
Sumeet,
what is 'sh proc cpu | ex 0.0' when you create that vlan?
what is 'sh span vlan ' ?
HTH,
Ivan.
Hi Sumeet,
Please check the hardware utilization of the switch like RAM, CPU.
IOS is doenst matter at this point it seems.
Any way did you upgrade from IP Base license to IP Services license?
Please rate the helpful posts.
Naidu.
Ven Taylor
Level 8
Level 8
Can you post your config?
That may help troubleshoot the issue you're seeing.
Ven Taylor
  By delay what are you talking about ?   Pinging an SVI is not a trrue indicator of response time, you need to ping to a live device on that vlan itself.   As as ip routing it either works or it doesn't  (turned off) .   For further help please post the config and more information about the problem.
