Airflow on a 93180yc
Paul Nuttall
Is it possible to change the Airflow Diretion on a 93180YC???
Thanks in advance
balaji.bandi
I have seen this  configuraiton on OLD Nexus 5K software based flow control- Looks that is more vulenrable command like kids playing with FAN with software config.)
i do not see Cisco that support in the new version of kit (nor i am aware of ) you need to buy right kit outside or inside flow based on the kit mounting in the rack
Fan modules (four) with the following airflow choices:
• Port-side intake airflow with burgundy coloring (NXA-FAN-30CFM-B)
• Port-side exhaust airflow with blue coloring (NXA-FAN-30CFM-F)
BB
pieterh
look at the datasheet of your model
NB! you need to match the power supply too !
Airflow
Port-side intake and exhaust
NXA-FAN-30CFM-F
Nexus Single Fan, 30CFM, port side exhaust airflow
NXA-FAN-30CFM-B
Nexus Single Fan, 30CFM, port side intake airflow
NXA-PAC-500W-PE
Nexus 9000 500W AC PS, Port-side Exhaust
NXA-PAC-500W-PE
NXA-PDC-930W-PI
Nexus 9000 930W DC PS, Port-side Intake
NXA-PDC-930W-PE
Nexus 9000 930W DC PS, Port-side Exhaust
