01-12-2011 12:06 PM - edited 03-06-2019 02:57 PM
Hello all,
Help please!
The led "uplink activity" in the cisco aironet 1400 -power injector lr- is off. I have checked coaxial and connectors, they are ok. I can not access the bridge by ethernet or telnet. I have reseted the bridge also, but the signal keep off. Is it a software/hardware problem?
01-14-2011 06:26 AM
If you trun the AP backwards, what lights do you see. There are three lights down at the bottom and there is a sequence in which they blink. Please keep an eye on the blinking LED's.
http://www.cisco.com/en/US/docs/wireless/bridge/1400/12.2_15_JA/configuration/guide/p15trb.html
http://www.cisco.com/en/US/docs/wireless/bridge/1400/installation/guide/higch6.html
I had the same problem and I upgraded the IOS on the bridges to the latest one and that did the trick. If it doesnot then its a hardware replacement.
HTH,
-as
01-14-2011 11:37 AM
Hello Amit Singh,
Thank you!
The bridge is on my desk now. Only the -Installed led- is blinking.
I have made complete reset of the bridge. Before and after the reset I can not access the bridge (ethernet or telnet), how can I upgrade the IOS on the bridge?
