Access-List configuration help
worldpeace
Community Member
Hello, I need insights on access-list configurations.
I have two subnets sitting on two separate VLANs as follows:
192.168.1.145/29
192.168.1.153/29
I need to permit access from a server (host IP address is 192.168.1.149) in subnet 192.168.1.145/29 to access the entire subnet 192.168.1.153/29 via port say 25... what subnet mask should I use for the destination address?
here's what i entered:
access-list it_dept permit tcp host 192.168.1.149 192.168.1.153 0.0.0.7 eq 25.
Please let me know if the above statement is correct and the correct subnet mask I should use.
6 Replies 6
lgijssel
Level 11
Level 11
You are making a mistake with the adressing.
In an acl you must use the network address where you entered the first host address:
192.168.1.145/29 should be 192.168.1.144/29
192.168.1.153/29 should be 192.168.1.152/29
The acl mask is correct: 0.0.0.7 (3 bits)
regards,
Leo
thanks Leo!
I will rate it
Thnx!
Keep up the good work.
Leo
lgijssel
Level 11
Level 11
Always glad to help. And thank you for not rating.
Peace for the World!
Leo
Nagaraja Thanthry
From your description, it seems like you want to access the server (.149) from the clients in .152 subnet. The access-list depends on where you apply it. If you apply it to the interface that is the default gateway for the server, then the access-list will look like below:
access-list it_dept permit tcp host 192.168.1.149 eq "Server Port" 192.168.1.152 0.0.0.7
If you apply it to the default gateway of the clients, then
access-list it_dept permit tcp 192.168.1.152 0.0.0.7 host 192.168.1.149 eq "Server port"
Hope this helps.
NT
