Aironet 702 - configuration issue
jacek.sydor
hi,
  I bought new Cisco Aironet 702. I have problem with configuration. I can't access to configure terminal option or to web setup. Below is startup screens from Aironet. There are few errors during startup process:
no ip http server
% Invalid input detected at '^' marker.
%Error opening flash:/ap1g1-rcvk9w8-mx/info (No such file or  directory)cisco AIR-CAP702I-E-K9 (MIPS74k) processor (revision 01) with  73728K/57344K bytes of memory.
I accessed to exec mode using default login and password but I couldn't access to configure terminal options. Why Cisco doesn't recognize this command?
AP5006.04a6.231e#conf te
startup process:
flash size 1MB, sector count = 64
Flash:  1 MB
Fetching MAC Address from 0x87fe3908
eth0: 50:06:04:a6:23:1e
ATHRSF1_PHY: Port 4, Negotiation timeout
Ethernet link down
eth0
Ether initialization ok!
Atheros on-chip NAND FLash Controller Driver, Version 0.1 (c) 2010 Atheros Communications, Ltd.
Ath Nand ID[87ff117c]: 2c:f1:80:95:02
ONFI MICRON      MT29F1G08ABADAWP
Micron NAND 128MiB 3,3V 8-bit [128MB]
====== NAND Parameters ======
sc = 0x87ff1158 bbt = 0x87f98360 bbt_size = 0x100 nf_ctrl = 0x344
page = 0x800 block = 0x20000 oob = 0x40
size = 128MB
Setting 0xb8116290 to 0x2a542d0f
Test Size=0x8000000, Start!!
RAM test complete!
PTD Init
MAC address check ok!
boot method:3
Hit "ESC" to stop autoboot:  0
Uncompressed size: 319299 = 0x4DF43
Loading .text @ 0x84000000 (205088 bytes)
Loading .rodata @ 0x84032120 (38400 bytes)
Loading .data @ 0x8403b720 (3200 bytes)
Loading .data.rel.local @ 0x8403c3a0 (992 bytes)
Loading .data.rel @ 0x8403c780 (124 bytes)
Loading .data.rel.ro.local @ 0x8403c7fc (92 bytes)
Loading .data.rel.ro @ 0x8403c858 (960 bytes)
Clearing .bss @ 0x8403cc20 (161112 bytes)
Clearing .scommon @ 0x84064178 (60 bytes)
## Starting application at 0x84000000 ...
IOS Secondary Bootloader - Starting system.
Ath Nand ID: 95:80:f1:2c:00
Using driver version 1 for media type 2
Valid buffers 120
total120  120
success found all blocks
start end 65 72
found in range
high low end 2335 2089 72
Xmodem file system is available.
mifs[0]: 10 files, 2 directories
mifs[0]: Total bytes     :  131334144
mifs[0]: Bytes used      :    7591936
mifs[0]: Bytes available :  123742208
mifs[0]: mifs fsck took 0 seconds.
Base Ethernet MAC address: 50:06:04:a6:23:1e
Setup MAC....
Waiting for PHY auto negotiation to complete...Port 4 Negogiation timeout.
Ethernet link is down.
Setting Drop CRC Errors, Pause Frames and Length Error frames
: cfg1 0x7 cfg2 0x7114
Loading "flash:/ap1g1-rcvk9w8-mx.152-4.JA/ap1g1-rcvk9w8-mx.152-4.JA"...############################################################################################################################################################################################################################################################################################################################################################
File "flash:/ap1g1-rcvk9w8-mx.152-4.JA/ap1g1-rcvk9w8-mx.152-4.JA" uncompressed and installed, entry point: 0x60080000
executing...
Stop MAC.
AP1G1 Starting...
cp0 timer begin value is set as 1000
prid= 1974C
Starts main.
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, ap1g1 Software (ap1g1-RCVK9W8-M), Version 15.2(4)JA, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2013 by Cisco Systems, Inc.
Compiled Tue 18-Jun-13 14:15 by prod_rel_team
Initializing flashfs...
Ath Nand ID: 95:80:F1:2C:00
Valid buffers 120
total120  120
start end 65 72
found in range
mifs[3]: 10 files, 2 directories
mifs[3]: Total bytes     : 131334144
mifs[3]: Bytes used      : 7591936
mifs[3]: Bytes available : 123742208
mifs[3]: mifs fsck took 2 seconds.
mifs[3]: Initialization complete.
...done Initializing flashfs.
Base Ethernet MAC address: 50:06:04:A6:23:1E
no ip http server
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Processor board ID KWC1717004X
MIPS74k CPU at 40Mhz, revision number 0x0000
Last reset from power-on
LWAPP image version 7.5.1.33
1 Gigabit Ethernet interface
32K bytes of flash-simulated non-volatile configuration memory.
Base ethernet MAC Address: 50:06:04:A6:23:1E
Part Number                          : 74-11077-01
PCA Assembly Number                  : 000-00000-00
PCA Revision Number                  :
PCB Serial Number                    : KWC1717004X
Top Assembly Part Number             : 000-00000-00
Top Assembly Serial Number           : KWC1717004X
Top Revision Number                  : 01
Product/Model Number                 : AIR-CAP702I-E-K9
% Please define a domain-name first.
logging facility kern
logging trap emergencies
Press RETURN to get started!
: Mac unit                :   0
: Max segments per packet :   1
: Max tx descriptor count :   128
: Max rx descriptor count :   256
: Mac capability flags    :   4400
athr_gmac_hw_setup mac: 0x61953F40
*Mar  1 00:00:13.683: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Mar  1 00:00:13.895: %LINK-6-UPDOWN: Interface GigabitEthernet0, changed state to up
*Mar  1 00:00:16.711: %SYS-5-RESTART: System restarted --
*Mar  1 00:00:16.731: *** not invoke
*Mar  1 00:00:16.751: %LWAPP-3-CLIENTERRORLOG: Config load from flash failed. Initialising Cfg
*Mar  1 00:00:16.755: %CAPWAP-3-ERRORLOG: Failed to load configuration from flash. Resetting to default config
*Mar  1 00:00:16.767: %PARSER-4-BADCFG: Unexpected end of configuration file.
lwapp_crypto_init: MIC Present and Parsed Successfully
*Mar  1 00:00:17.723: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to up
User Access Verification
Username: Cisco
no bridge-group 1 source-learning
%Default route without gateway, if not a point-to-point interface, may impact performance
Password:
*Mar  1 00:00:47.195: %LINK-6-UPDOWN: Interface BVI1, changed state to down
*Mar  1 00:00:48.195: %LINEPROTO-5-UPDOWN: Line protocol on Interface BVI1, changed state to down
AP5006.04a6.231e>enable
Password:
6 Replies 6
blenka
Level 3
Level 3
if, the ethernet and radio interface is up kindly check if the band is selected means a,b,g & n.
Greg Savage
I have the same problem .
I can login to the CAP702i through the console port, but can't get access to the "Configuration terminal" commands.
I am thinking the the Flash file "ap1g1-rcvk9w8-mx.152-4.JA" is the issue.
I have downloaded an updated file from the Cisco web site, but with not way to install it, I can't determine if it is what's causing the problem.
I connected the CAP702i to a DHCP server, and it is pulling a valid IP, but I am unable to Telnet, browse or use Network Assistant to access the GUI setup.
I am able to ping the CAP702i, but that's about extent of it functionality so far.
Hi Buddy
Did you find a fix to this? I have the exact same problem on a 702W
Kamran
The problem was that I purchased the wrong model:
CAP702I  - CAP = Controller based Access Point.
SAP702I   - SAP = Standalone Access Point.
Either return the CAP model for a SAP model or you need to download and update the firmware
for a SAP702i.
The proper firmware can be found on the Cisco Support site. (link below)
The file I used : ag1g1-k9w7-tar.152-4.JB5.tar
http://software.cisco.com/download/release.html?mdfid=284741752&softwareid=284180979&os=&release=15.2.4-JB5&relind=AVAILABLE&rellifecycle=&reltype=latest&i=!pp
You will need to connect the AP702 to a DHCP server so it can grab a IP address.
Install the Cisco HTTP program to update the Firmware, and reboot the AP702.
I have the same Issue, can you explain what is the Cisco HTTP program?
The AP is always renewing the IP using DHCP because it doesn't find a WLC.
Thank you
Best Regards
I will attach the configuration manual I used to transfer the new firmware file.
scg15_2_4_JB3a.pdf
The commands are pretty vague in the manual, and if you are not familiar the command structure, I would contact Cisco support.
You will need to install the TFTP server and have the firmware file before contacting support.
