11-05-2022 05:23 AM
I have a serious issue on my hands with a Nexus 3K switch. We just upgraded to 3.0(2)A8(11b) from 6.0.2.A8.10. So not a big jump. It was meant to be the first in a series of upgrades, but that is another matter.
All SVI's are showing Protocol Down, and the VPC Peerlink is down because it can't talk to IP address on the other side of the peer link.
The interfaces themselves for the peerlink are showing up, and the port channel for the peer link is up. all other VPC port channels are down. I can't ping the peer link IP address even from the local switch, so obviously nothing else can reach it either.
1# sh vpc
Legend:
(*) - local vPC is down, forwarding via vPC peer-link
vPC domain id : 11
Peer status : peer link is down
vPC keep-alive status : peer is not reachable through peer-keepalive
Configuration consistency status : failed
Per-vlan consistency status : success
Configuration inconsistency reason: Consistency Check Not Performed
Type-2 inconsistency reason : Consistency Check Not Performed
vPC role : none established
Number of vPCs configured : 7
Peer Gateway : Enabled
Peer gateway excluded VLANs : -
Dual-active excluded VLANs : -
Graceful Consistency Check : Disabled (due to peer configuration)
Operational Layer3 Peer-router : Disabled
Auto-recovery status : Disabled
vPC Peer-link status
id Port Status Active vlans
1 Po11 up -
vPC status
id Port Status Consistency Reason Active vlans
311 Po311 down Not Consistency Check Not -
Applicable Performed
2133 Po2133 down Not Consistency Check Not -
2292 Po2292 down Not Consistency Check Not -
2303 Po2303 down Not Consistency Check Not -
2319 Po2319 down Not Consistency Check Not -
2321 Po2321 down Not Consistency Check Not -
2322 Po2322 down Not Consistency Check Not -
1#
1#
1# sh ip int br
IP Interface Status for VRF "default"(1)
Interface IP Address Interface Status
Vlan302 protocol-down/link-down/admin-up
Vlan2142 protocol-down/link-down/admin-up
Vlan2181 protocol-down/link-down/admin-up
Vlan2348 protocol-down/link-down/admin-up
Vlan3110 protocol-down/link-down/admin-up
1# show spanning-tree vlan 3110
Spanning tree instance(s) for vlan does not exist
There are no blocked ports in spanning tree
11-05-2022 06:27 AM
vPC keep-alive status : peer is not reachable through peer-keepalive <<-
can you share config of vpc peer-keepalive ?
11-05-2022 06:50 AM
vPC domain id : 11
before upgrade, have done the testing is everything ok as per the upgrade test ?
how are you saving the config - sync or each device ?
this is output from switch1 ( so can you share the same output from other side of the switch)
Looks for me Port-channnel 11 and peer link may have gone error disable.
show port-channel summary port-channel 11 (bot the device)
show interface ethx/x part of PO11 (from both the switches)
