allow vlans in trunk port is not working
Mordecalex
Hi, i would like my web server just accept traffic from vlan 20 (i got 3 multilayer switches with vlan 20) but when i use my central switch and enter the following commands:
enable
config term
int g0/1
switchport trunk allow vlan 20
my server stop receiving traffic from every vlan, why is that? am i missing some step?
here is the file from packet tracer
When you configure g0/1 as a trunk the result is that all vlans are allowed on the trunk. When you add the command
the result is that only vlan 20 is allowed on the trunk. All other vlans are not allowed on that trunk.
We do not know much about your environment and what you are attempting to achieve. But if you have a server and you want only vlan 20 to be able to access the server then I would suggest that a good solution would be to use an access list to restrict access.
Rick
allow vlan 20 ?? I think you need to allow vlan1 also.
Rick
An addition to the excellent point that @Richard Burts made is that the default on a trunk is to allow all known VLAN's. If you are trying to pass a VLAN through a switch and it doesn't know about it, that traffic will get dropped. VTP transparent will (I think) let unknown VLAN's pass, but any other VTP mode will definitely not pass unknown VLAN's.
I am glad that our suggestions have been helpful. Thank you for marking this question as solved. This will help other participants in the community to identify discussions which have helpful information. This community is an excellent place to ask questions and to learn about networking. I hope to see you continue to be active in the community.
Rick
