allowing vlans in trunk
vishalpatil86
hi,
i have configured switch 2960 with gig0/1 trunk port..
when i type cmd sh int gig0/1 trunk, it shows me following -
sw#sh int gig 0/1 trunk
Port        Mode             Encapsulation  Status        Native vlan
Gi0/1       on               802.1q         other         10
Port        Vlans allowed on trunk
Gi0/1       none
Port        Vlans allowed and active in management domain
Gi0/1       none
Port        Vlans in spanning tree forwarding state and not pruned
Gi0/1       none
how come it is not showing allowed vlans? kindly suggest.
Antonio Knox
Level 7
Level 7
If this is a fresh configuration, and the interface is not up and connected to a trunking switch, this is what you will see in the output until you connect it to a switch that will bring up the trunk.  Follow the basic rules of trunking between the switches (switchport, switchport mode, encapsulation and native vlan) and you should see the trunking info.
johnlloyd_13
Level 9
Level 9
Hi Vishal,
You would need to manually add those vlans.
Switch(config-if)#switchport trunk allowed vlan
Make a show run int gig0/1 or do a show int gig0/1 switchport to see the results.
fabio.marino
Hi Vishal, in order to see allowed vlan on your switch is enough to use the "show interface trunk" command. In this way you can see the allowed vlan for each port of your switch.
Antonio Knox
Level 7
Level 7
thanx antonio, i agree with u.....its perfectly correct.
