Alternative switch to Cisco Catalyst 3750v2-24FS and 3750-24FS
paulwalliman1
I`m looking for an alternative to these two switches:
1.  WS-C3750V2-24FS-S  Cisco Catalyst 3750V2-24FS Switch with 24 100FX SFP + 2 Gigabit Ethernet SFP Ports
2. Cisco Catalyst 3750-24FS (WS-C3750-24FS-S 100BASE-FX)
They are now EOL and not available.
I have a campus style network and need to be able to connect multiple 100FX fibre switches back to a central switch. The 1st unit uses 100FX SFP modules and the second has in-built 100FX ports. I`m struggling to find anything from Cisco that will give me multiple (i.e 12+) 100FX ports.
Could anyone please point me in the right direction?
Many thanks,
Paul
Sandeep Choudhary
Hi Paul ,
Replacement for both switch is WS-C3650-48TS-S.
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5528/eos-eol-notice-c51-730227.html
http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps5023/end_of_life_c51-687707.html
Don't forget to rate helpful posts
Hi Sandeep,
Spot on. Glaringly obvious when you know where to look but I`ve skipped through the documentation loads of times and completely missed it.
Many thanks,
Paul
Sandeep I think you mean the WS-C3750X-24S-S - That's the one with fiber ports in the base unit.
The 48TS model has 48 copper user ports (plus the four SFP-based based ports).
I'll agree with Marvin on this.  The only 24-port single-RU-all-SFP-model is the WS-C3750X-24S.
WS-C3750X-12S & WS-C3750X-24S will support GLC-GE-100FX in any of the ports (including the optional module).
Not sure how far away is the all-SFP 3850 is, so this is out of the question.
