Any caveats with regards to replacing switch stack with different hardware and software versions?
garethtex
I am replacing an existing switch stack as the switches are end of life and I need more port capacity
Switch Ports Model              SW Version            SW Image
*    1 28    WS-C3750G-24TS     12.2(44)SE2           C3750-IPBASEK9-M
     2 28    WS-C3750G-24TS-1U  12.2(44)SE2           C3750-IPBASEK9-M
with a new switch stack
     1 30    WS-C3750X-24       12.2(58)SE2           C3750E-UNIVERSALK9-M
*    2 30    WS-C3750X-24       12.2(58)SE2           C3750E-UNIVERSALK9-M
     3 30    WS-C3750X-24       12.2(58)SE2           C3750E-UNIVERSALK9-M
the new switch stack has an IPBASE license installed.
Are there any caveats around taking the configuration on the existing switch stack and copying to the new switch stack as the hardware, SW Version and SW image are different?
Any help would be greatly appreciated.
Thanks.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of   the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
From 12.2(44) to 12.2(58), there's a good chance the latter can digest the config of the former, although after it's done so, if you compare them, you're likely see some differences (beyond the additional ports provided by the third stack member).
BTW, unless you need (58) features, I would suggest using (55)SE9.
Joseph W. Doherty
Disclaimer
Posting
Thanks for replying. Is the reason you suggest using (55)SE9 due stability of the IOS? Are there issues with (58). These are new switches are were shipped with the (58) IOS.
Disclaimer
Posting
Yes, as you suspect, recommending (55)SE9 because it appears to be a very stable/solid release.
