Archive Command Question
Patrick McHenry
Level 4
Level 4
I really like the archive command. Makes saving configs after changes much easier. One question about the command sample that was posted that I am using on our switches.
archive
log config
  logging size 1000
  notify syslog contenttype plaintext
  hidekeys
path tftp://XX.XX.XX.XX/Main_Campus/XXX0/XXX01/XXX01
write-memory
I understand what each of the lines is accomplishing except for the logging size 1000. If I am saving to a external tftp server, do I really need it? And, is there any harm in keeping it?
When I do a "sh archive" I see a record of the write configs.
XXX21#sh arch
The maximum archive configurations allowed is 14.
The next archive file will be named tftp://XX.XX.XX.XX/Main_Campus/XXX2/XXX21/XXX21-<timestamp>-4
Archive #  Name
  1        tftp://XX.XX.XX.XX/Main_Campus/XXX2/XXX21/XXX21Aug--7-15-59-39.552-0
  2        tftp://XX.XX.XX.XX/Main_Campus/XXX2/XXX21/XXX21Aug--8-10-48-23.605-1
  3        tftp://XX.XX.XX.XX/Main_Campus/XXX2/XXX21/XXX21Aug--8-10-56-28.886-2
  4        tftp://XX.XX.XX.XX/Main_Campus/XXX2/XXX21/XXX21Aug-15-06-16-06.365-3                    <- Most Recent
Is this just informing me that configs have been saved or is it saving them locally as well?
Thanks, Pat.
Hi Pat,
Router(config-archive-log-config)# hidekeys (hides passwords from being shown / logged)
If you have "hidekeys" command configured under the archive, it wont save your passwords to tftp server which means it wont log the entry of passwords.
And logging size command is used to specify the maximum number of entries retained in the configuration log. The config will save to tftp server not locally on switch.
And "sh acrchive" will tell you how many archives you have in the tftp server for particular switch. Say for example archive 1 which means the first archive. Now you have done some change in that switch then tftp server will take another archive with name archive 2 like that it will show you a order of all the saved archives.
If you copied the saved config to new switch then you would need to edit the saved password (it will be like *******) in notepad and type the new password.
Hope i clear you...
Please rate the helpfull posts.
Naidu.
8 Replies 8
Latchum Naidu
Hi Pat,
The logging size command is to specify the maximum number of entries retained in the configuration log. This is not required actually.
And the "show archive" providing you the details of the currently archived ones and your next archived one will be 5.
And also I observed that you dont have "hidekeys" command configured under the archive. So configure this command immediately because it wont log the entry of passwords.
Naidu.
Naidu,
I do have the hidekeys.
I didn't really give this command much thought, though. I thought it was just encrypting the keys as they went across the network?
Question - Just to clarify. If I have the hidekeys command, this will save my local and enable passwords to the tftp server?
also, I was wondering if the logging size 1000 is saving the configs to the swicth locally as well as to the tftp server? Or, is the output from the "sh acrchive" command just telling me that configs have been saved.
Thanks, Pat.
hidekeys command in configuration change logger configuration mode is used to suppress the display of password information in configuration log files. Enabling the hidekeys command increases security by preventing password information from being displayed in configuration log files. Applies to both the passwords.
"sh archive" tells you that the configs have been saved at tftp server with so and so name.
Find the link for explanation of each command in my above post.
Cheers
Sweta
Please rate useful posts.
smogra
To specify the maximum number of entries retained in the configuration log, we use the logging size command in configuration change logger configuration mode.
Refer this link for a explanantion of all the commands used in archiving:
http://www.cisco.com/en/US/docs/ios/12_3t/12_3t4/feature/guide/gtconlog.html#wp1032378
Valid values range for logging size is from 1 to 1000. The default value is 100 entries. So, even you dont mention it to be 1000, be default, it will save onlly 100 entries.
Hope that helps.
Cheers
Sweta
Please rate the helpful posts.
Sweta, thanks for the link.
I just need to have clarification on what is happening with the hidekeys command. In the doc it says that it supresses the passwords.
So, if I copied the saved config to a new switch, would I have to then enter the password manually?
Hi Pat,
Hope i clear you...
Naidu.
Thanks Naidu,
so, the "sh archive"in my case, is merey telling me about the configs saved in my tftp server?
Hi Pat,
You are most welcome and thanks for your rating.
And YES the "show archive" in your case is telling you about the saved configs in your tftp server.
Naidu.
