Archive Command
Patrick McHenry
Level 7
Level 7
I've added the archive command with some success. With the last switch I'm adding it to I'm having some problems. I entered the config as I have for the others but, it wouldn't seem to write to the file even though it looked correct so, I decided to enter it again and got this message:
ACB13(config-archive)#path tftp://Main_Campus/ACB1/ACB13/ACB13
Archive is being written, cannot change path now - please try again later.
Any suggestions? Is there a way to kill archive that is being written?
Thanks, Pat.
Somasundaram Jayaraman
can you try removing the path and try adding it again.
following are the outputs from my lab device
cisco_2#sh archive
Archive feature not enabled
cisco_2#conf ter
Enter configuration commands, one per line.  End with CNTL/Z.
cisco_2(config)#archive
cisco_2(config-archive)#path tftp://test3
cisco_2(config-archive)#exit
cisco_2(config)#do wr
Building configuration...
[OK]
cisco_2(config)#do sh archi
The maximum archive configurations allowed is 14.
The next archive file will be named tftp://test3--0
Archive #  Name
   7
   8
   9
cisco_2(config-archive)#no path tftp://test3
[OK]
cisco_2(config)#do sh archive
cisco_2(config)#
http://www.cisco.com/en/US/docs/ios/12_3t/fun/command/reference/cfrgt_01.html#wp1094316
Cheers
Somu
Rate this answer if the content found useful
cisco_2#sh archive
cisco_2#conf ter
[OK]
Archive #  Name
   7
   8
   9
[OK]
cisco_2(config)#
Cheers
Somu
Thanks, Somu. Worked great.
