Archive
amarmn1975
Level 4
Level 4
Hii,
Can anybody tell me how to use the archive command in to save routers and switch configuration in tftp server in a cretin time (daily or weekly  ...)
5 Replies 5
Ganesh Hariharan
Hii,
Check out the link below for kron policy configuration for scehdular backup on cisco devices hope that help
http://www.configureterminal.com/free/kron.html
If helpful do rate the post
Ganesh.H
Sybren.Apiecionek_2
Community Member
amarmn1975
for weekly backup, your config should be:
ip tftp source-interface "fill_in_interface"
The archiving commands are:
archive
log config
  logging enable
  logging size 200
(<= This is the number of "comands issued by user X" that is saved in memory (if you use AAA, you can trace who changed what))
path tftp://IP_address/filename.txt
write-memory
(<= The config is saved to the tftp server if you perform a "write memory" or a "copy run start")
time-period 10800
(<= 10800 saves your config weekly, this is good enough if your network doesn't change daily).
but I prefer to use FTP as you can protect it with a username/password, if you use FTP it will look like:
ip ftp source-interface "fill_in_interface"
ip ftp username "username"
ip ftp password "password"
service password-encryption
archive
  log config
   logging enable
   logging size 200
(<= This is the number of "last comands issued by user X" is saved in memory (if you use AAA, you can trace who changed what))
  path ftp://IP_address/filename.txt
  write-memory
(<= The config is saved to the tftp server if you use a "write memory" or a "copy run start")
  time-period 10800
milan.kulik
Level 11
Level 11
you could use the archive ... time-period command, see http://www.cisco.com/en/US/docs/ios/12_3t/fun/command/reference/cfrgt_12.html#wp1058010
But IMHO, it's more useful to use archive ...write-memory
command to save your config into the archive every time you save the running- config into the startup-config.
HTH,
Milan
Milan
as you can see: I prefer to use time-priod & write-memory both in my config.
In case your collegue "forgets" to save the config, it is at least saved weekly 🙂
Grt
S
yes, I understand.
But then you've got many config copies with no change in fact.
Each solution has pros and cons 🙂
BR,
Milan
