Are Nexus 5596UP & Nexus 2248TP GE compatible with SFP-10G-SR?
Andy L
Hello
I am looking to see if Nexus 5596UP & Nexus 2248TP GE compatible with SFP-10G-SR?
The reason is because a consultant was hired on to "design" the network layout and has decided to purchase Cisco SFP+ Copper Twinax Cables which have a 10M limit. A small handful of the Data Center racks are 10-15M away... just out of reach of the Twinax. I would prefer NOT to move the LAN row so that it is more centered in the room. Can I use the SFP-10G-SR to connect the 2 switches (5596 & 2248) together? This SFP has a 26M reach on standard 10gig fiber, the small cost increase per connection is of no concern.
Andy
Jerry Ye
Yes, it is supported. Table 2
http://www.cisco.com/en/US/prod/collateral/switches/ps9441/ps9670/data_sheet_c78-618603.html
If this is only between the Nexus 5596 and Nexus 2000s, you can also use the FET (suppose to be cheaper).
HTH,
jerry
Outstanding!! Thank you
