Are these switches bad? - New to Cisco and Networking
TechNeil
I recieved 4 2-c3850-24xs-e switches and they all have the same error (see below)
I read that running the following command would fix it "emergency-install usbflash0:cat3k_caa-universalk9.16.12.08.SPA.bin" I ran this command and it formatted the flash updated the flash with the newest, it boots all the way and shows no errors except for what is below.
My fluke linkrunner is able to connect to the internet through the switch so I think I am missing something obviously.
Booting...
Interface GE 0 link down***ERROR: PHY link is down
The "IP_ADDR" environment variable is not set.
Getting rest of image
Reading full image into memory...Check base package header ...: done = 16384
Reading full image into memory....done
Reading full base package into memory...: done = 32791733
Bundle Image
Kernel Address : 0x537783c4
Kernel Size : 0x4381df/4424159
Initramfs Address : 0x53bb05a3
Initramfs Size : 0x1ab4f12/28004114
Compression Format: mzip
Bootable image at @ ram:0x537783c4
Bootable image segment 0 address range [0x81100000, 0x81da5280] is in range [0x80180000, 0x90000000].
@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@@boot_system: 623
Loading Linux kernel with entry point 0x81895bf0 ...
Bootloader: Done loading app on core_mask: 0x3f
### Launching Linux Kernel (flags = 0x5)
Linux version 4.9.187 (sumikum7@sjc-ads-5670) (gcc version 5.3.0 (GCC) ) #1 SMP Fri Nov 19 03:09:46 PST 2021
CVMSEG size: 2 cache lines (256 bytes)
Cavium Inc. SDK-5.1.0
bootconsole [early0] enabled
CPU0 revision is: 000d900a (Cavium Octeon II)
Checking for the multiply/shift bug... no.
Checking for the daddiu bug... no.
%IOSXEBOOT-3748f25d3076de52df7db2641f93e50c-new_cksum: (rp/0): 4
%IOSXEBOOT-3748f25d3076de52df7db2641f93e50c-saved_cksum: (rp/0): 4
Final tar file: mcu_ucode_bundle_6_2_0.tar
Both links down, not waiting for other switches
Switch number is 2
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
Cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software [Gibraltar], Catalyst L3 Switch Software (CAT3K_CAA-UNIVERSALK9-M), Version 16.12.8, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2022 by Cisco Systems, Inc.
Compiled Thu 15-Sep-22 06:03 by mcpre
This software version supports only Smart Licensing as the software licensing mechanism.
PLEASE READ THE FOLLOWING TERMS CAREFULLY. INSTALLING THE LICENSE OR
LICENSE KEY PROVIDED FOR ANY CISCO SOFTWARE PRODUCT, PRODUCT FEATURE,
AND/OR SUBSEQUENTLY PROVIDED SOFTWARE FEATURES (COLLECTIVELY, THE
"SOFTWARE"), AND/OR USING SUCH SOFTWARE CONSTITUTES YOUR FULL
ACCEPTANCE OF THE FOLLOWING TERMS. YOU MUST NOT PROCEED FURTHER IF YOU
ARE NOT WILLING TO BE BOUND BY ALL THE TERMS SET FORTH HEREIN.
Your use of the Software is subject to the Cisco End User License Agreement
(EULA) and any relevant supplemental terms (SEULA) found at
http://www.cisco.com/c/en/us/about/legal/cloud-and-software/software-terms.html.
You hereby acknowledge and agree that certain Software and/or features are
licensed for a particular term, that the license to such Software and/or
features is valid only for the applicable term and that such Software and/or
features may be shut down or otherwise terminated by Cisco after expiration
of the applicable license term (e.g., 90-day trial period). Cisco reserves
the right to terminate any such Software feature electronically or by any
other means available. While Cisco may provide alerts, it is your sole
responsibility to monitor your usage of any such term Software feature to
ensure that your systems and networks are prepared for a shutdown of the
Software feature.
FIPS: Flash Key Check : Begin
FIPS: Flash Key Check : End, Not Found, FIPS Mode Not Enabled
All TCP AO KDF Tests Pass
cisco WS-C3850-24XS (MIPS) processor (revision J0) with 794816K/6147K bytes of memory.
Processor board ID xxx
2048K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
255037K bytes of Crash Files at crashinfo:.
3435916K bytes of Flash at flash:.
0K bytes of WebUI ODM Files at webui:.
Base Ethernet MAC Address : 00:08:32:ad:07:00
Motherboard Assembly Number : xxx
Motherboard Serial Number : xxx
Model Revision Number : J0
Motherboard Revision Number : A0
Model Number : WS-C3850-24XS
System Serial Number : xxx
Press RETURN to get started!
*Apr 3 23:09:03.239: %SMART_LIC-6-EXPORT_CONTROLLED: Usage of export controlled features is not allowed
*Apr 3 23:09:04.623: %SMART_LIC-6-AGENT_READY: Smart Agent for Licensing is initialized
*Apr 3 23:09:04.624: %SMART_LIC-6-AGENT_ENABLED: Smart Agent for Licensing is enabled
*Apr 3 23:09:04.625: %SMART_LIC-6-EXPORT_CONTROLLED: Usage of export controlled features is not allowedRA Tracing tool registry return: 0
*Apr 3 23:09:13.937: %SPANTREE-5-EXTENDED_SYSID: Extended SysId enabled for type vlan
*Apr 3 23:09:15.039: %LINK-3-UPDOWN: Interface Lsmpi19/3, changed state to up
*Apr 3 23:09:15.040: %LINK-3-UPDOWN: Interface EOBC19/1, changed state to up
*Apr 3 23:09:15.041: %LINEPROTO-5-UPDOWN: Line protocol on Interface LI-Null0, changed state to up
*Apr 3 23:09:15.042: %LINK-3-UPDOWN: Interface GigabitEthernet0/0, changed state to down
*Apr 3 23:09:15.042: %LINK-3-UPDOWN: Interface LIIN19/2, changed state to up
*Apr 3 23:09:15.270: %HMANRP-6-HMAN_IOS_CHANNEL_INFO: HMAN-IOS channel event for switch 2: EMP_RELAY: Channel UP!
*Apr 3 23:08:48.395: %STACKMGR-6-STACK_LINK_CHANGE: Switch 2 R0/0: stack_mgr: Stack port 1 on Switch 2 is nocable
*Apr 3 23:08:48.395: %STACKMGR-6-STACK_LINK_CHANGE: Switch 2 R0/0: stack_mgr: Stack port 2 on Switch 2 is down
*Apr 3 23:08:48.395: %STACKMGR-6-STACK_LINK_CHANGE: Switch 2 R0/0: stack_mgr: Stack port 2 on Switch 2 is nocable
*Apr 3 23:08:48.396: %STACKMGR-4-SWITCH_ADDED: Switch 2 R0/0: stack_mgr: Switch 2 has been added to the stack.
*Apr 3 23:08:51.363: %STACKMGR-4-SWITCH_ADDED: Switch 2 R0/0: stack_mgr: Switch 2 has been added to the stack.
*Apr 3 23:08:53.364: %STACKMGR-4-SWITCH_ADDED: Switch 2 R0/0: stack_mgr: Switch 2 has been added to the stack.
*Apr 3 23:08:53.365: %STACKMGR-6-ACTIVE_ELECTED: Switch 2 R0/0: stack_mgr: Switch 2 has been elected ACTIVE.
*Apr 3 23:09:15.280: %HMANRP-6-EMP_NO_ELECTION_INFO: Could not elect active EMP switch, setting emp active switch to 0: EMP_RELAY: Could not elect switch with mgmt port UP
*Apr 3 23:09:15.293: %SMART_LIC-6-HA_ROLE_CHANGED: Smart Agent HA role changed to Active.
*Apr 3 23:09:16.058: %LINEPROTO-5-UPDOWN: Line protocol on Interface Lsmpi19/3, changed state to up
*Apr 3 23:09:16.058: %LINEPROTO-5-UPDOWN: Line protocol on Interface EOBC19/1, changed state to up
*Apr 3 23:09:16.059: %LINEPROTO-5-UPDOWN: Line protocol on Interface GigabitEthernet0/0, changed state to down
*Apr 3 23:09:16.059: %LINEPROTO-5-UPDOWN: Line protocol on Interface LIIN19/2, changed state to up
*Apr 3 23:09:16.698: %SYS-5-CONFIG_P: Configured programmatically by process MGMT VRF Process from console as vty0
*Apr 3 23:09:16.719: %IOSXE_MGMTVRF-6-CREATE_SUCCESS_INFO: Management vrf Mgmt-vrf created with ID 1, ipv4 table-id 0x1, ipv6 table-id 0x1E000001
*Apr 3 23:09:16.744: %SYS-5-CONFIG_P: Configured programmatically by process MGMT VRF Process from console as vty0
*Apr 3 23:09:17.186: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to down
*Apr 3 23:09:18.858: %SYS-7-NVRAM_INIT_WAIT_TIME: Waited 0 seconds for NVRAM to be available
*Apr 3 23:09:19.125: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named TP-self-signed-4285827411 has been generated or imported by crypto config
*Apr 3 23:09:19.236: %ONEP_BASE-6-SS_ENABLED: ONEP: Service set Base was enabled by Default
*Apr 3 23:09:19.291: %PKI-6-TRUSTPOINT_CREATE: Trustpoint: SLA-TrustPoint created succesfully
*Apr 3 23:09:19.301: %PKI-6-TRUSTPOINT_CREATE: Trustpoint: TP-self-signed-4285827411 created succesfully
*Apr 3 23:09:19.599: %SYS-5-CONFIG_I: Configured from memory by console
*Apr 3 23:09:19.771: %SYS-5-CONFIG_P: Configured programmatically by process CPP MQC QoS Policy manager from console as vty1
*Apr 3 23:09:20.358: %SYS-5-RESTART: System restarted --
*Apr 3 23:09:20.451: %SSH-5-ENABLED: SSH 1.99 has been enabled
*Apr 3 23:09:20.829: %EVENT_TRACE-6-ENABLE: Trace already enabled.
*Apr 3 23:09:20.830: %EVENT_TRACE-6-ENABLE: Trace already enabled.
*Apr 3 23:09:21.488: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named TP-self-signed-4285827411.server has been generated or imported by crypto-engine
*Apr 3 23:09:22.687: %LINK-5-CHANGED: Interface GigabitEthernet0/0, changed state to administratively down
*Apr 3 23:09:22.688: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/1/1, changed state to down
*Apr 3 23:09:22.688: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/1/2, changed state to down
*Apr 3 23:09:22.688: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/1/3, changed state to down
*Apr 3 23:09:22.689: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/1/4, changed state to down
*Apr 3 23:09:22.689: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/1/5, changed state to down
*Apr 3 23:09:22.689: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/1/6, changed state to down
*Apr 3 23:09:22.689: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/1/7, changed state to down
*Apr 3 23:09:22.690: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/1/8, changed state to down
*Apr 3 23:09:22.690: %LINK-3-UPDOWN: Interface FortyGigabitEthernet2/1/1, changed state to down
*Apr 3 23:09:22.691: %LINK-3-UPDOWN: Interface FortyGigabitEthernet2/1/2, changed state to down
*Apr 3 23:09:22.691: %LINK-3-UPDOWN: Interface Vlan1, changed state to up
*Apr 3 23:09:23.691: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet2/1/1, changed state to down
*Apr 3 23:09:23.692: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet2/1/2, changed state to down
*Apr 3 23:09:23.692: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet2/1/3, changed state to down
*Apr 3 23:09:23.692: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet2/1/4, changed state to down
*Apr 3 23:09:23.692: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet2/1/5, changed state to down
*Apr 3 23:09:23.693: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet2/1/6, changed state to down
*Apr 3 23:09:23.693: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet2/1/7, changed state to down
*Apr 3 23:09:23.693: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet2/1/8, changed state to down
*Apr 3 23:09:23.693: %LINEPROTO-5-UPDOWN: Line protocol on Interface FortyGigabitEthernet2/1/1, changed state to down
*Apr 3 23:09:23.694: %LINEPROTO-5-UPDOWN: Line protocol on Interface FortyGigabitEthernet2/1/2, changed state to down
*Apr 3 23:09:25.728: %PNP-6-PNP_DISCOVERY_STOPPED: PnP Discovery stopped (Startup Config Present)
*Apr 3 23:09:29.528: %HMANRP-6-EMP_NO_ELECTION_INFO: Could not elect active EMP switch, setting emp active switch to 0: EMP_RELAY: Could not elect switch with mgmt port UP
*Apr 3 23:09:29.818: %SYS-5-CONFIG_P: Configured programmatically by process EPM CREATE DEFAULT CWA URL ACL from console as console
*Apr 3 23:09:33.265: %PLATFORM_PM-6-MODULE_INSERTED: SFP module inserted with interface name Te2/0/1
*Apr 3 23:09:34.075: %PKI-2-NON_AUTHORITATIVE_CLOCK: PKI functions can not be initialized until an authoritative time source, like NTP, can be obtained.
*Apr 3 23:09:34.093: %PKI-6-TRUSTPOINT_CREATE: Trustpoint: CISCO_IDEVID_SUDI_LEGACY created succesfully
*Apr 3 23:09:34.122: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named CISCO_IDEVID_SUDI_LEGACY has been generated or imported by pki-sudi
*Apr 3 23:09:34.194: %PKI-6-TRUSTPOINT_CREATE: Trustpoint: CISCO_IDEVID_SUDI_LEGACY0 created succesfully
*Apr 3 23:09:34.203: %PKI-6-TRUSTPOINT_CREATE: Trustpoint: CISCO_IDEVID_SUDI created succesfully
*Apr 3 23:09:34.228: %CRYPTO_ENGINE-5-KEY_ADDITION: A key named CISCO_IDEVID_SUDI has been generated or imported by pki-sudi
*Apr 3 23:09:34.363: %PKI-6-TRUSTPOINT_CREATE: Trustpoint: CISCO_IDEVID_SUDI0 created succesfully
*Apr 3 23:09:38.496: %LINK-3-UPDOWN: Interface TenGigabitEthernet2/0/1, changed state to up
*Apr 3 23:09:39.512: %LINEPROTO-5-UPDOWN: Line protocol on Interface TenGigabitEthernet2/0/1, changed state to up
*Apr 3 23:09:40.912: %LINEPROTO-5-UPDOWN: Line protocol on Interface Vlan1, changed state to up
*Apr 3 23:09:51.364: %SMART_LIC-6-EXPORT_CONTROLLED: Usage of export controlled features is not allowed
*Apr 3 23:09:51.365: %CALL_HOME-6-CALL_HOME_ENABLED: Call-home is enabled by Smart Agent for Licensing.
Switch>
0 Replies 0
