Nexus C93180YC-FX with Dell Unity XT 380F
RBordais
Good morning,
Would you be able to tell me how to interconnect a Nexus C93180YC-FX (on a 10/25 Gbit/s Ethernet port) with a Dell Unity XT 380F (25 GbE optical I/O module, block and file access) by iSCSI to create a convergence point between storage and ESXi servers via the Nexus.
Thank you and have a good day.
Reza Sharifi
If you have the correct SFPs (MM or SM) than all you need is the cable to go with type of SFPs you have.
balaji.bandi
If other side only accept 25G, you need to install  same SFP and test it.
BB
RBordais
Thank you for your answers.
Do we agree that a lag in iSCSI is not possible?
Thanks.
Usually lag is not needed, as the physical links can handle the failover from one to another just fine.
